Sampo AlphaScan 950  21 in.CRT Conventional Monitor
Problems with Sampo AlphaScan 950 21 in.CRT Conventional Monitor?
Keep your PC up-to-date. Get a Free Scan for Sampo's latest driver updates.
Troubleshooting and Support
Solved Problems for Sampo AlphaScan 950  21 in.CRT Conventional Monitor RSS Feed Post a New Problem
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
Acer Aspire 1710 laptop monitor is down
Hi, monitor on my laptop went black in a moment. Looks like computer is continuing to work. When making a closer look at...
1 Solution
Monitor trouble
I have a westinghouse monitor and we had a wind storm .My server went down for about 5 minutes and when it did my...
1 Solution
L222WT flatron 21.6 monitor is not working
When the monitor is turned on, the LG symbol/logo appears as if it will then go to the Windows Vista page. Instead,...
1 Solution
bzzzing noise coming from monitor
my monitor is making noises, like an electrical bzzz. Could it be a corrupt profile or is it hardware? other than that,...
1 Solution
dell monitor for dimension 2350
lately my monitor keeps blanking out... I was told that a patch could fix the problem.. I hooked another monitor to the...
1 Solution
.ct 2070 display not clear
Hi,  we have the lct 2070 akai monitor.  I have hooked it to the computer and its working but, the fonts are...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Size21"
Max. Resolution1600 x 1200
Dot Pitch0.28 mm
Monitor TypeCRT
Technical Features
Form FactorDesktop
Dimensions
Depth19.5 in.
Height20.88 in.
Width19.9 in.
Weight57.33 lb.
Warranty
Warranty3 Years
Sampo Contact Information
Main support number1-888-373-4368
Email supportinfo@regent-usa.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
Jaimie Guru
1 solutions
Ask Me
radarman1 Wiz
2 solutions
Ask Me
ntg1976 Guru
2 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
