FixYa.com
RCA LCSD2022B  20.1 in. Flat Panel LCD Monitor
All Products > RCA > Monitors
Problems with RCA LCSD2022B 20.1 in. Flat Panel LCD Monitor?
Search inside RCA LCSD2022B 20.1 in. Flat Panel LCD... Knowledgebase
Troubleshooting and Support
Solved Problems for RCA LCSD2022B  20.1 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
How to clean Screens of High End Monitors?
1 Solution
My laptop screen is experiencing burn-in...
My laptop screen is experiencing burn-in along the taskbar. Is this normal?
1 Solution
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
The monitor turns off and on repeatedly.
It comes on and shows the picture but then turns off and comes back on and shows the picture and turns off again...
1 Solution
Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. ...
1 Solution
faulty screen
the screen has like waves going across,it comes and goes,ive tried different cables,and i moved it to another room,and...
1 Solution
Blank screen
Screen is blank, power light is blinking green. Disconnecting the video connection makes no difference. A substitute...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio4:3
Size20.1"
Color Depth24-bit (16.7M colors)
Contrast Ratio500:1
Brightness500 cd/m
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time16 ms
Viewable Picture Size20.1 in.
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Audio InputStereo Mini-Connector
Max. Viewing Angle - Horizontal160
Max. Viewing Angle - Vertical160
Native (Recommended) Resolution800 x 600
Dimensions
Depth2.97 in.
Height17.44 in.
Width24.6 in.
Weight33.1 lb.
RCA Contact Information
Main support number580-634-0151
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
