FixYa.com
Neovo E-19A  19" LCD Monitor
All Products > Neovo > Monitors
Problems with Neovo E-19A 19" LCD Monitor?
Troubleshooting and Support
Solved Problems for Neovo E-19A  19" LCD Monitor RSS Feed Post a New Problem
Screen goes black in half a second....
We have a Neovo E-19A monitor that turns on and has signal for about a half a second, then it goes black, with the LED...
3 Solutions
blackouts
I have a E-19A monitor, while working on the computer the screen will just black out, (power light still green) wait a...
1 Solution
external speakers do not play
I have external speakers boston Acoustics Digital BA735 which do not produce sound on certain internet sites like you...
1 Solution
Power problem?
I have one of these monitors but not the original power adapter, so i use a universal.The Power seems to come on the go...
1 Solution
no display
the stand by light goes from orange to green the no signal dispay comes on then goes...but the display does not turn on....
1 Solution
faulty screen
the screen has like waves going across,it comes and goes,ive tried different cables,and i moved it to another room,and...
1 Solution
MONITOR REPAIR HELP
Hi I would like to appreciate for your help I have got an Acer monitor model G781 CRT Type its switching power...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size19"
Color Depth24-bit (16.7M colors)
Contrast Ratio700:1
Brightness300 cd/m
Max. Resolution1280 x 1024
Dot Pitch0.29 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time25 ms
Viewable Picture Size19 in.
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Audio InputStereo Mini-Connector
Regulatory ApprovalBSMI · CE · UL · cUL · FCC Class B · CB · TCO-95 · ISO 13406-2 (Pixel defect guidelines) · GOST-R · CCC
Digital Video Input StandardDigital Visual Interface (DVI)
Synchronization Range - Horizontal24 - 80 kHz
Max. Viewing Angle - Horizontal170
Max. Viewing Angle - Vertical170
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768
Synchronization Range - Vertical49 - 75 Hz
Dimensions
Depth7.7 in.
Height17.7 in.
Width17.2 in.
Weight16.1 lb.
Neovo Contact Information
Main support number1-408-321-8210
Email supportservice@neovo-usa.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
