20 Most Recent
Sharp VL-E685U 8mm Analog Camcorder Questions & Answers
Dew
was the unit exposed to the cold? you just have to wait it out if so otherwise you have a bad sensor.
good luck
please mark the post with a fixya
Where can I find the PC Connect cable for a Sharp Camcorder Model VL-SD2OU
You may be able to find the PC Connect cable for your Sharp Camcorder Model VL-SD2OU at an electronics store or online retailer that specializes in video and camera equipment. You can also try contacting Sharp directly to see if they have the cable in stock or if they can suggest a retailer that carries it. Alternatively, you may be able to use a generic USB cable to connect your camcorder to your computer, depending on the capabilities of your camcorder and computer.
Keep in mind that you may need to install any necessary software or drivers on your computer before you will be able to access the video files on your camcorder
How can I find a US repair shop to have my Sharp Hi-8 camcorder repaired? A
Newton Ellis & Co. repair most makes and models of camcorders and video cameras. If you are having a problem with your camcorder or video camera then bring or send it in for a free estimate, we can usually give you an idea of what is wrong with it and an idea of the cost. If you can't get in to our shop then give us a call and we will try to help you over the phone or just send an email, see the 'Contact Us' page. We do try to make the repairs as cost effective as possible so if you have an older model then we will try our best to keep the cost down if at all possible.
E commerce Software ecommerce software solution & Online Shopping Cart for small business
https://www.tritansolutions.com/Home/Ecommerce-Solutions
