20 Most Recent
Samsung VP-D77i Mini DV Digital Camcorder Questions & Answers
How do I get my Samsung sc d 353 mini DV tape recordings on computer
To transfer the recordings from your Samsung SC D353 Mini DV tape to your computer, you'll need to follow these steps:
1. Connect the camcorder to your computer: Use a FireWire (also called IEEE 1394) cable to connect your Samsung SC D353 Mini DV camcorder to your computer. Most computers have a FireWire port, but if yours doesn't, you can purchase a FireWire adapter card.
2. Turn on the camcorder: Turn on your Samsung camcorder and set it to VCR mode.
3. Open the video capture software: On your computer, open the video capture software that came with your operating system (e.g. Windows Movie Maker, iMovie on Mac) or a third-party video capture software (e.g. Adobe Premiere Pro, Final Cut Pro) that supports Mini DV tape.
4. Start recording: In the video capture software, select the option to capture video from a DV device. Click the Record button in the software and then press Play on the camcorder to begin playing the Mini DV tape. The video should be captured and recorded onto your computer.
5. Save the video: Once the video has been captured, you can edit it if necessary and then save it to your computer in the desired format.
Note: If you do not have the original video capture software, it is recommended that you search and download compatible software before beginning the transfer process. Additionally, make sure your computer has enough storage to store the transferred files.
Samsung SC-D353 foggy lens - what can I do?
If the lens on your Samsung SC-D353 camcorder is foggy, there are a few steps you can try to clear it:
- Clean the lens using a lens cleaning solution and a soft, lint-free cloth. Be sure to gently wipe the lens in a circular motion, taking care not to scratch it.
- If the foggy appearance persists, there may be moisture inside the camcorder. You can try using a hair dryer or a can of compressed air to blow out any moisture that may be trapped inside the camcorder.
- If the foggy appearance is still present after trying these steps, there may be an issue with the lens itself. In this case, you may need to have the camcorder serviced by a professional.
I hope this helps! If you have any further questions or if you are having trouble clearing the foggy lens on your camcorder, don't hesitate to ask.
Samsung VP-D103 flashlight not turning off.
Please remove the memory card and hold the power button down for 15 seconds. If that does not turn the light off, please remove all batteries from your device. Please stay away from the power outlet where the camcorder was initially charging. Thank you.
Driver for Samsung SCD6040
Log in to Samsung web site , enter make and model on the driver site. if there is a update driver download it there .
Unlock samsunge 3210 phone pls
By using Unlock Code you can unlock your Samsung e 3210 . You can get the unlock code from
Superunlockcodes.com . There you need to
specify your Country and Current network name to get the unlock code. They will give you unlock code along with instructions on how to unlock. Follow the instructions and unlock your Samsung e 3210 .
