Sharp LL-172CB  17 in. Flat Panel LCD Monitor
Problems with Sharp LL-172CB 17 in. Flat Panel LCD Monitor?
Keep your PC up-to-date. Get a Free Scan for Sharp's latest driver updates.
Troubleshooting and Support
Solved Problems for Sharp LL-172CB  17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
any good resources so that I can learn to...
I work as a tech for an educational institution and we have numerous Gateway (brand) FPDs that have either lamp or...
1 Solution
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
LG 500G MONITOR
IN MY MONITOR HORIZONTAL OUTPUT TRANSISTOR(C5855) FOUND SHORT. I REPLACED IT BUT AFTER FEW MINUITS IT BECAME...
1 Solution
hi lcd
hi, the screen of my monitor(computer) when i open a some game are shaking
1 Solution
monitor takes 1/2 hour to warm up
when switching on my computer it takes at least 1/2 hr for the monitor to show anything, once the images appear...
1 Solution
hi light is going dim day by day
i am using microtek monitor..but the light/brightness is going dim day by day...what is the problem what should i do?...
1 Solution
Connecting my LCDTV upto my Computer
I'm trying to connect my LCD Monitor to my computer and when i follow the instructions in my manual it tells me to go...
1 Solution
Unsolved Support Problems
Unsolved Problems for Sharp LL-172CB  17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
LL-172CB, 17'LCD monitor
There is not power for my LCD monitor, no power LED on front of the monitor, I checked the fuses and i found them Ok, i...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio450:1
Brightness300 cd/m
Max. Resolution1280 x 1024
Dot Pitch.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time16 ms
Viewable Picture Size17 in.
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s) · Headphone
Max. Viewing Angle - Horizontal160
Max. Viewing Angle - Vertical135
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024
Dimensions
Depth8.1 in.
Height14.7 in.
Width14.7 in.
Weight13.2 lb.
Sharp Contact Information
Main support number1-800-237-4277, 1-800-BE SHARP
Support FAX1-630-378-9981
Sponsored Links
Loading problems.
Top Experts
Ask Me
ntg1976 Guru
2 solutions
Ask Me
Microwave Guru
2 solutions
Ask Me
silly gir Wiz
1 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
