FixYa.com
Pixie 950  19 in.CRT Conventional Monitor
All Products > Pixie > Monitors
Problems with Pixie 950 19 in.CRT Conventional Monitor?
Search inside Pixie 950 19 in.CRT Conventional... Knowledgebase
Troubleshooting and Support
Solved Problems for Pixie 950  19 in.CRT Conventional Monitor RSS Feed Post a New Problem
How to clean Screens of High End Monitors?
1 Solution
My laptop screen is experiencing burn-in...
My laptop screen is experiencing burn-in along the taskbar. Is this normal?
1 Solution
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
The monitor turns off and on repeatedly.
It comes on and shows the picture but then turns off and comes back on and shows the picture and turns off again...
1 Solution
Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. ...
1 Solution
faulty screen
the screen has like waves going across,it comes and goes,ive tried different cables,and i moved it to another room,and...
1 Solution
Blank screen
Screen is blank, power light is blinking green. Disconnecting the video connection makes no difference. A substitute...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Pixie 950  19 in.CRT Conventional Monitor RSS Feed Post a New Problem
Pixie 950 Monitor
The screen image seems to be faded and not able to adjust contrast or brightness to correct. What seems to be the...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size19"
Max. Resolution1280 x 1024
Dot Pitch0.25 mm
Monitor TypeCRT
Technical Features
Form FactorDesktop
Dimensions
Depth22.46 in.
Height21.67 in.
Width18.12 in.
Weight48.51 lb.
Warranty
Warranty3 Years
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
