FixYa.com
Acer AcerView 56C  15 in.CRT Conventional Monitor
All Products > Acer > Monitors
Problems with Acer AcerView 56C 15 in.CRT Conventional Monitor?
Search inside Acer AcerView 56C 15 in.CRT... Knowledgebase
Troubleshooting and Support
Solved Problems for Acer AcerView 56C  15 in.CRT Conventional Monitor RSS Feed Post a New Problem
Acer 56c Problems??
Hi! I have an 8-month old AcerView 56c that has started to tint everything blue.  Is this a problem with...
3 Solutions
The monitor turns off and on repeatedly.
It comes on and shows the picture but then turns off and comes back on and shows the picture and turns off again...
1 Solution
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
How to clean Screens of High End Monitors?
1 Solution
My laptop screen is experiencing burn-in...
My laptop screen is experiencing burn-in along the taskbar. Is this normal?
1 Solution
Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. ...
1 Solution
faulty screen
the screen has like waves going across,it comes and goes,ive tried different cables,and i moved it to another room,and...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size15"
Max. Resolution1280 x 1024
Dot Pitch0.28 mm
Monitor TypeCRT
Technical Features
Form FactorDesktop
Dimensions
Depth15.17 in.
Height14.7 in.
Width14.81 in.
Weight27.56 lb.
Warranty
Warranty3 Years
Acer Contact Information
Main support number408.432.6200 1.800.733.2237
Support FAX408.922.2933
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
