Acer AC713   17" CRT Monitor
Problems with Acer AC713 17" CRT Monitor?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Acer AC713 (White) (Black, Ivory) 17"...
Troubleshooting and Support
Solved Problems for Acer AC713   17" CRT Monitor RSS Feed
Click here to get instant support from our best Experts!
View More Results for Acer AC713 17" CRT Monitor
Questions and Unsolved Support Problems
Unsolved Problems for Acer AC713   17" CRT Monitor RSS Feed
Answer
I'm looking for a flat screen monitor for my ACER computer. The resolution goes from ( 800 x 600... (More)
Answer
Everytime I turn on the computer the monitor adjustment screen is there and I can't change anything... (More)
Answer
in my system midea player cannot play because sound device is not install, he is giving information... (More)
Answer
monitor adjustment menu appears in the screen and adjusts the settings automatically
Answer
in my CRT monotor automatically adjusting the brightness and Contrast to maxium level
Answer
I opend an acer AC713 color 17" CRT. The problem is that there is no contrast at all.... (More)
Find a Manual
Acer AC713 17" CRT Monitor Manuals & Guides
WikiManual
(Post a New Chapter)
How to Fix a Scratch on an LCD Screen
Use Vaseline petroleum jelly to fill a scratch on an LCD screen. This works because the optical density more closely matches the LCD face than air.... by wikihow
How to Fix a Stuck Pixel on an LCD Monitor
If your LCD screen has a stuck or dead pixel (a point on the screen that is always lit or always dark), it is usually due to a transistor malfunction... by wikihow
How to Improve Image Quality on an LCD Monitor
One method to improve the display on an LCD monitor is to use a DVI connector on a DVI capable video card. This is due to the fact that LCD monitors... by wikihow
Upload Manuals
Tips & How To Guides for the Acer AC713 17" CRT Monitor
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
How to remove the case on LCD monitors
This tip will explain how to open the case on most LCD monitors. Most monitors will eventually have a problem with the power supply and need... written by buddymc
USE YOUR LCD TV AS A COMPUTER MONITOR BY WAY OF HDMI.
To use your LCD TV as a monitor. look for a HDMI output on the computer and the TV. If you dont have a HDMI output on the computer, you will need to... written by tbrat44
Monitor led is blinking or steady, but the display does not come up
The monitor is probably on protection. To start unplug monitor from power and from computer and test computer with different monitor to find out if... written by ginko
Hannspree, I-inc, Hannsg
Don't buy and products from this company they get cheap parts from companies going out of business. They are built to break down as soon as the... written by worthy42
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
Determine if you are having problems with your monitor or video card in...
Many people have problems determining if their monitor is bad or their video card is bad. One good way to test this is by swapping out your monitor... written by BobbyR1234
if there is discoloration then follow this
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ... so what you have to do is... written by dileep007
LCD and CRT monitors: The fist things you should check
When having problems with any monitor the following are the first things you should check when troubleshooting: 1. Check to make sure the power source... written by BobbyR1234
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Acer AC713 17" CRT Monitor
Nationwide | 877-934-6198 | Website
Send your laptop to us and we will diagnose the pro... Read More
Featured Listing
Nationwide | (952)890-7770 | Website
Zkarlo.com provides discount and used laptop parts for... Read More
Featured Listing
Nationwide | 5138743306 | Website
We fix and repair laptop motherboard no video, no pow... Read More
Featured Listing
Nationwide | 8005882188
Featured Listing
Nationwide | 8664878724
Featured Listing
Nationwide | 8004130133 | Website
We offer computer consulting services, hardware and... Read More
Nationwide | 407-284-1943 | Website
Affordable Laptop and Desktop Repair. We spe... Read More
Nationwide | 254-718-4042 | Website
we Service most consumer electronics. cb's twoway ham... Read More
Nationwide | 601-918-0222
I will connect to your Computer and repair the tro... Read More
Nationwide | 4695217517 | Website
We repair LCD Monitors and TV's. We also carry a lar... Read More
Ratings for the
Find a Warranty
Specifications for Acer AC713 17" CRT Monitor
Key Features
Size
17"
Max. Resolution
1280 x 1024
Dot Pitch
.27 mm
Monitor Type
CRT
Viewable Picture Size
17 in.
Technical Features
Form Factor
Desktop
Regulatory Approval
CE · UL · cUL · FCC Class B · TUV-GS · DHHS · Energy star · TCO-03 · MPR-II
Synchronization Range - Horizontal
30 - 70 kHz
Native (Recommended) Resolution
1024 x 768
Resolutions supported
1280 x 1024 · 1024 x 768
Synchronization Range - Vertical
50 - 160 Hz
Dimensions
Depth
16.48 in.
Height
16.77 in.
Width
15.93 in.
Weight
35.27 lb.
Acer Contact Information
Main support number408.432.6200 1.800.733.2237
Support FAX408.922.2933
Describe your problem:
Top Monitor Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
