This seems like a leaky output capacitor. Trace the wire from the deflection coils (in the yoke) that leads to a fairly large electrolytic capacitor (usually less than 1000 uf, 220 or 470 uf and rated at more than 100 volts)Replace with new one.
Electrolytics have limited lifespan.
Take care when working with TV and monitor. Some large capacitor can retain charges even after the power is off. wait about 1 minute or 2 after pulling the plug before touching anything.
Good luck
I disconnect the cable that connects the CPU, the cables came off, I need the connecting diagram for the monitor AOC 1770, the combination of the cables in the connector to the CPU, thanks
Try Reinstalling: Sometimes, software issues can be resolved by simply reinstalling the program. Try uninstalling the AOC i-menu software from your computer and then downloading and installing it again from the official AOC website.
Check Compatibility: Make sure that the version of the i-menu software you downloaded is compatible with your operating system. If you're using Windows 10, for example, ensure that you've downloaded the version of the software designed for Windows 10.
Update Drivers: Ensure that your monitor drivers are up to date. Sometimes, outdated drivers can cause compatibility issues with software like i-menu. You can usually find driver updates on the AOC website or through your computer's device manager.
Contact Portrait Displays: Despite the difficulty in reaching them, continue trying to contact Portrait Displays through the link provided by AOC support. You can also try reaching out to them through their social media channels or any other contact information you can find online.
Check Community Forums: Sometimes, other users might have experienced similar issues with the i-menu software and found solutions on community forums or discussion boards. Try searching online for any threads related to your problem and see if there are any suggested fixes.
Alternative Solutions: While waiting for support, consider alternative software solutions for adjusting your monitor settings. There may be third-party software available that can provide similar functionality to i-menu.
On the Windows 10 login screen you will need to press control,alt,delete and press and hold down the alt key and release the delete and then finally release the keys then,
Now enter your ID and the password.
You will need to press the enter key or click on the right arrow button.
please look for a button with a sun icon above it. Usually pressing that button and the using the corresponding arrows on the device should allow you to alter the brightness.
Thank you.
If the computer is running Windows 7 judging from the age of the computer you may need to update the operating system and then get new drivers for the NVIDIA card.
GEE YES, ANY PC CAN HAVE NEW MONITOR ANY CAN,IS THIS A PRE SALES QUESTION OR WHAT?IF BOTH PC/MON ARE IN FACT HDMI ?WE DO NOT KNOW HOW YOU USE A PC EVER. AND MATTERS TOO.1: EMAIL, CRUISE WEB ONLY?2; WATCH STREAMING 4K VIDEOS AT NETFLIX.?3: OR PLAY AAA NEW $70 GAMES, ON STEAM.?what stops you>? from trying? it will not catch fire tired,no monitor told at all , vast models 1979 to now.VAST SOLD AND VAST HMDI AND VAST PERFORMANCE DIFFERENCES AND MAXIMUM RESOLUTION LIMITS.ALSO A TV CONNECTS TO ANY HDMI PC. BUT IS SLOW THE SCREEN IS FOR PC WORK AS SOME COMPLAIN.
no PC told,. no AOC model told, answers would be 10pages long.
we can not guess either
AOC HAD MONITORS FROM 1979 NOT NOW.
SO MEANS LITTLE, JUST MAKERS NAME.
A loose connection between your monitor and your PC will trigger the monitor no signal issue. If you're seeing the no signal message on your screen when your Windows system is running, the first thing you should check is whether your compatible video cable is firmly connected or not
no PC told at all model, if is a PC, I have NVR CCTV system here with a VGA monitor.no monitor told at all no model, AOC told and vast there are even back to 1979 CRT vacuum tube screens. yes.we can not see your screen to see how bad it is.but if the PC is set to max resolution of your monitorand using VGA are you? , not the digital ports.VGA , the monitor has OSD button, marked MENUpush that (RTM) and see screen settingsbingo for POSITION Vert / Horzsome models have auto setting there (a choice) but can fail. so do it manually if that fails.The PC as class of system can in fact sometimes be sit to illgall(sic) resolution that monitor can not do.vast exist, and most monitors can not do them allso NO PC told , no AOC toldand not video card told if present in any desktop PC.sorry can not answer more , lacking all facts.
AOC MAKES MANY THINGSPC'S Tablets or the BreezeTV'smonitors and moreno clue told by you nor the model numberno PC told if is PCno monitor told if is monitor.no photos of failing screens posted
