FixYa.com
Acer AL2032wd   20 in. Flat Panel LCD Monitor
All Products > Acer > Monitors
Problems with Acer AL2032wd 20 in. Flat Panel LCD Monitor?
Search inside Acer AL2032wd 20 in. Flat Panel LCD... Knowledgebase
Troubleshooting and Support
Solved Problems for Acer AL2032wd   20 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
My dvi receiver doesnt work
My monitior stop picking up a signal from the dvi cable..it was picking it up fine and now it just stopped...what can i...
1 Solution
Chargable service format
Sir how we should explain if we r charging some amt. on services provided by our service centre what format should be...
1 Solution
ibm c51
i have done a clean install for win. xp but now i cannot adjust the resulotion or colour on my ibm c51 monitor.hope you...
1 Solution
noisy sound from monitor
Hi my LG desktop monitor is giving me a noisy sound when it is plugged to external tv tunner card.it will start making...
1 Solution
NEW MONITOR NOISES
My new monitor is making clicking sounds from the back any ideas? thankyou.
1 Solution
Changed graphics card-then disabled the...
I replaced the graphics card on a spare PC, but couldn't install it so changed back to the old one, but before doing so,...
2 Solutions
green led light flashing on 700p proview...
hello, i have a proview 17in flat panel computer monitor model #700p that will not show anything, and the green power...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Acer AL2032wd   20 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
monitor turns on and then off right away...
turn on computer, monitor clicks on, then strobes once, then click off again. this keeps going on and on and on and on...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size20"
Contrast Ratio600:1
Brightness300 cd/m
Max. Resolution1680 x 1050
Dot Pitch.258 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time16 ms
Viewable Picture Size20 in.
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Digital Video Input StandardDVI-D
Max. Viewing Angle - Horizontal178
Max. Viewing Angle - Vertical178
Dimensions
Depth8.1 in.
Height17.5 in.
Width20.1 in.
Acer Contact Information
Main support number408.432.6200 1.800.733.2237
Support FAX408.922.2933
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
