Apple Cinema HD  23" LCD Monitor
Problems with Apple Cinema HD 23" LCD Monitor?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Apple Cinema HD (White) 23" LCD Monitor
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Apple Cinema HD  23" LCD Monitor RSS Feed
Click here to get instant support from our best Experts!
View More Results for Apple Cinema HD 23" LCD Monitor
Questions and Unsolved Support Problems
Unsolved Problems for Apple Cinema HD  23" LCD Monitor RSS Feed
Answer
I have an apple monitor that doesn't seem to work all the time. I turned off my laptop and when I... (More)
Answer
can i use this on a new macbook? if so what adaptor do i need?
Answer
I unplugged my Apple Cinema HD Display 23" (White) from my PC to plug it back into my MacBook... (More)
Answer
Como puedo solucionar el problema de mi monitor, se apaga, nose si tenga que mandarlo a reparar o yo... (More)
Answer
my monitor screen is doing just that .there is no floashing on the power button just this damnable... (More)
Find a Manual
Apple Cinema HD 23" LCD Monitor Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
How to remove the case on LCD monitors
This tip will explain how to open the case on most LCD monitors. Most monitors will eventually have a problem with the power supply and need... written by buddymc
USE YOUR LCD TV AS A COMPUTER MONITOR BY WAY OF HDMI.
To use your LCD TV as a monitor. look for a HDMI output on the computer and the TV. If you dont have a HDMI output on the computer, you will need to... written by tbrat44
Monitor led is blinking or steady, but the display does not come up
The monitor is probably on protection. To start unplug monitor from power and from computer and test computer with different monitor to find out if... written by ginko
Hannspree, I-inc, Hannsg
Don't buy and products from this company they get cheap parts from companies going out of business. They are built to break down as soon as the... written by worthy42
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
Determine if you are having problems with your monitor or video card in...
Many people have problems determining if their monitor is bad or their video card is bad. One good way to test this is by swapping out your monitor... written by BobbyR1234
if there is discoloration then follow this
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ... so what you have to do is... written by dileep007
LCD and CRT monitors: The fist things you should check
When having problems with any monitor the following are the first things you should check when troubleshooting: 1. Check to make sure the power source... written by BobbyR1234
WikiManual
(Post a New Chapter)
How to Fix a Scratch on an LCD Screen
Use Vaseline petroleum jelly to fill a scratch on an LCD screen. This works because the optical density more closely matches the LCD face than air.... by wikihow
How to Fix a Stuck Pixel on an LCD Monitor
If your LCD screen has a stuck or dead pixel (a point on the screen that is always lit or always dark), it is usually due to a transistor malfunction... by wikihow
How to Improve Image Quality on an LCD Monitor
One method to improve the display on an LCD monitor is to use a DVI connector on a DVI capable video card. This is due to the fact that LCD monitors... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Apple Cinema HD 23" LCD Monitor
Nationwide | (877)729-0812 | Website
We connect to your computer over the Internet to qui... Read More
Featured Listing
Nationwide | 5138743306 | Website
We fix and repair laptop motherboard no video, no pow... Read More
Featured Listing
Nationwide | (952)890-7770 | Website
Zkarlo.com provides discount and used laptop parts for... Read More
Featured Listing
Nationwide | 877-934-6198 | Website
Send your laptop to us and we will diagnose the pro... Read More
Featured Listing
Nationwide | 8664878724
Featured Listing
Nationwide | 8005882188
Featured Listing
Nationwide | 8004130133 | Website
We offer computer consulting services, hardware and... Read More
Nationwide | 407-284-1943 | Website
Affordable Laptop and Desktop Repair. We spe... Read More
Nationwide | 254-718-4042 | Website
we Service most consumer electronics. cb's twoway ham... Read More
Nationwide | 601-918-0222
I will connect to your Computer and repair the tro... Read More
Ratings for the Apple Cinema HD (White) 23" LCD Monitor
0
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Rate and Review the Apple Cinema HD 23" LCD Monitor
Write a review:
Rate this product:
Would you recommend the Cinema HD (White) 23" LCD Monitor to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Apple Cinema HD 23" LCD Monitor
Key Features
Aspect Ratio
16:9
Size
23"
Color Depth
24-bit (16.7M colors)
Contrast Ratio
350:1
Brightness
200 cd/m
Max. Resolution
1920 x 1200
Dot Pitch
.258 mm
Monitor Type
Flat Panel LCD TFT (Active Matrix)
Viewable Picture Size
23 in.
Technical Features
Form Factor
Desktop
Regulatory Approval
UL · FCC Class B · CSA · TCO-95 · ISO 13406-2 (Pixel defect guidelines) · Energy star · MPR-II · VCC-B
Max. Viewing Angle - Horizontal
170
Max. Viewing Angle - Vertical
170
Native (Recommended) Resolution
1920 x 1200
Dimensions
Depth
7.37 in.
Height
19.15 in.
Width
24.19 in.
Weight
25.36 lb.
Warranty
Warranty
1 Year
Apple Contact Information
Main support number1-800-275-2273
Describe your problem:
Top Monitors Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
