FixYa.com
BenQ CFP531  15 in. Flat Panel LCD Monitor
All Products > BenQ > Monitors
Problems with BenQ CFP531 15 in. Flat Panel LCD Monitor?
Search inside BenQ CFP531 15 in. Flat Panel LCD... Knowledgebase
Troubleshooting and Support
Solved Problems for BenQ CFP531  15 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
How to clean Screens of High End Monitors?
1 Solution
I have heard about putting a monitor in...
I have heard about putting a monitor in "sleep mode" to save electricity. What is that, and how do I do it?
1 Solution
My laptop screen is experiencing burn-in...
My laptop screen is experiencing burn-in along the taskbar. Is this normal?
1 Solution
what does it take, really, to get an old...
what does it take, really, to get an old PC to learn some new TV tricks?
1 Solution
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
The monitor turns off and on repeatedly.
It comes on and shows the picture but then turns off and comes back on and shows the picture and turns off again...
1 Solution
sceptre LCD - no display
My Sceptre LCD X9G-Komodo IV is no longer worked as usual, the screen stopped displaying. If I press the button OFF and...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size15"
Color Depth24-bit (16.7M colors)
Contrast Ratio400:1
Brightness250 cd/m
Max. Resolution1024 x 768
Dot Pitch.297 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time25 ms
Viewable Picture Size15 in.
Technical Features
Form FactorDesktop
Synchronization Range - Horizontal31 - 63 kHz
Max. Viewing Angle - Horizontal120
Max. Viewing Angle - Vertical100
Native (Recommended) Resolution1024 x 768
Synchronization Range - Vertical56 - 75 Hz
Dimensions
Depth5.4 in.
Height13.3 In.
Width13 in.
Weight8.2 lb.
Warranty
Warranty3 Years
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
