FixYa.com
BenQ FP767  17" LCD Monitor
All Products > BenQ > Monitors
Problems with BenQ FP767 17" LCD Monitor?
Troubleshooting and Support
Solved Problems for BenQ FP767  17" LCD Monitor RSS Feed Post a New Problem
BenQ FP767 17" Problem: Monitor wont...
I have a BenQ FP767 Monitor when I hook up the power supply and press the button to turn it on nothing happens the light...
3 Solutions
No Audio
I can't get any audio sound through the speakers that are built in to the monitor. If I try to edit the audio options in...
1 Solution
Monitor on but no/very feint display
Second & third faults are the inverters. (power but no image visible, but feint if you shine a light into the...
1 Solution
BenQ FP767 contrast keeps appearing
Hi hopefully you can help. The contrast setting keeps appearing and adjusting itself for no apparent reason. Have tried...
1 Solution
how to get audio from a benq fp767 lcd...
how do i get audio from my benq fp767 lcd monitor
1 Solution
BenQ FP767 17" LCD Monitor Problem
I HAVE A BENQ FP767. WHEN I TURN IT ON I GET A GREEN LIGHT BUT IT TURNS ON AND OFF. I READ ON THE BOARDS TO TEST...
1 Solution
display
POWER LIGHT IS ON BUT NO DISPLAY ..
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio500:1
Brightness260 cd/m
Max. Resolution1280 x 1024
Dot Pitch.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time16 ms
Viewable Picture Size17 in.
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Regulatory ApprovalBSMI · CE · UL · FCC Class B · C-Tick · CB · TUV-GS · ISO 13406-2 (Pixel defect guidelines) · TCO-99 · TCO-03 · TUV-ERGO · GOST-R · FIMKO
Synchronization Range - Horizontal30 - 83 kHz
Max. Viewing Angle - Horizontal160
Max. Viewing Angle - Vertical160
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 1152 x 864 · 1152 x 870 · 720 x 400 · 640 x 350 · 1152 x 900
Synchronization Range - Vertical50 - 76 Hz
Dimensions
Depth7.9 in.
Height15.9 in.
Width15 in.
Weight9.7 lb.
Warranty
Warranty3 Years
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
