FixYa.com
BenQ FP737S-D  17" LCD Monitor
All Products > BenQ > Monitors
Problems with BenQ FP737S-D 17" LCD Monitor?
Troubleshooting and Support
Solved Problems for BenQ FP737S-D  17" LCD Monitor RSS Feed Post a New Problem
benq fp737s monitor failure
my benq fp737s lcd monitor will only power on for milli-seconds and then turns itself off automatically. i have had it...
1 Solution
LCD monitor went blank
My BenQ LCD monitor went blank when I was busy with my work. It is not my tower because I tested it with a different...
1 Solution
Light is green, but monitor just goes on...
I found a few people with similar problems, but since I have soldered two things in my life I am afraid to break it if I...
3 Solutions
Benq 17"Lcd monitor fault
Benq17"lcd monitor Computer running with valid output. Turn on lcd, no benq logo, bands of moving horizontal and...
1 Solution
LCD panel no display
The panel showns no display but BENQ flashes on and off
1 Solution
Benq FP737 LCD Display
When I power off the system by wall socket, The display (Benq FP737) of my PC also off. But the problem is, when I on...
1 Solution
benq fp737s monitor dead
hi there, ive read your info on fixing but having probs finding the transistors you mention. i have board in front of me...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for BenQ FP737S-D  17" LCD Monitor RSS Feed Post a New Problem
advice
thanks for help, i dont think id trust myself to try fixing it myself. would it be easy? wouldnt i need static strips...
Post a Solution
found them
ah found them....so if i change these 4 will it make the screen work again?? do i test them as a normal transistor test...
Post a Solution
Vertical lines intermittantly on turn...
Remove mains and reconnect, usually ok for a while..
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size17"
Color Depth24-bit (16.7M colors)
Max. Resolution1280 x 1024
Dot Pitch0.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Technical Features
Form FactorDesktop
Digital Video Input StandardDigital Visual Interface (DVI)
Dimensions
Depth6.1 in.
Height14.8 in.
Width14.5 in.
Weight9.7 lb.
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
