Troubleshooting & Support for
13,754 people viewed this product
The monitor should be replaced, by your description there is more than one issue, it has a screen dis...
Use the CTRL-ALT-ARROW combination to flip the screen around. This is a problem that occurs when som...
all you have to do is hold ctrl + alt and press the up arrow key and your problem will be fixed
i had the same problem.i called up the service senter of samsung and they were like, press the menu but...
I have a Samsung SyncMaster 712n I turned the computer on , but my screen is black and the power lig...
If you are going to DIY and already try the monitor with another PC, and have proper tools and know saf...
It does the same when attached to another PC, Video cable and connectios are good? If you are going to ...
open the case remove little white plug from rear of switches leave it out close case job done no mor...
Your video card and computer memory may not be sufficient to run in the recommended "optimum per...
It sounds like the backlights circuits are no longer working properly. Most failure is due to bad cap...
Eliminate your graphics card / chip by trying a different monitor, if this works ok, then your ssue is ...
Most likely you will need to reinstall the video card driver. This will allow you to select a more des...
Hi What you see on the screen is normal, No signal message, check signal cable. The actual problem of ...
Did you use the combination keys of your laptop Fn and either F5, 6, or 7 depends on brand to select int...
Please try this monitor with other PC first, if it still have the same problem then you need to open it ...
Have a tip for Samsung SyncMaster 712N 17" Flat Panel LCD Monitor?
My monitor was working yesterday, but then I accidentally pressed a couple of buttons and now its...
Have a Samsung syncmaster 712N and the brightness menu wont come off the screen and it increases by...
Brightness box will not go off screen. I have pressed the exit button but it only stays off for a...
Little Brightness Screen keeps popping up; says 100 percent. How can I get rid of it and make it...
the brightness and the Auto Adjustment lock pop in and out.
I just noticed a 5' horizontal line on my Samsung monitor. Is this the beginning of the end for the...
I have a Samsung SyncMaster 712n plugged into my toshoba laptop. I am running windows 7. The first...
brightness screen keeps popping up how do I make it stop?
| Key Features | |||
| Full Product Name | Samsung SyncMaster 712N 17" Flat Panel LCD Monitor | ||
| Also Known As | Samsung SyncMaster 712N (Black) 17 in. Flat Panel LCD Monitor |
| Aspect Ratio | 4:3 | ||
| Size | 17" | ||
| Color Depth | 24-bit (16.7M colors) | ||
| Contrast Ratio | 600:1 | ||
| Brightness | 300 cd/m | ||
| Max. Resolution | 1280 x 1024 | ||
| Dot Pitch | 264 mm | ||
| Monitor Type | Flat Panel LCD TFT (Active Matrix) | ||
| Response Time | 12 ms | ||
| Viewable Picture Size | 17 in. | ||
| Technical Features | |||
| Form Factor | Desktop | ||
| Regulatory Approval | TCO-95 | ||
| Synchronization Range - Horizontal | 30 - 81 kHz | ||
| Max. Viewing Angle - Horizontal | 160 | ||
| Max. Viewing Angle - Vertical | 140 | ||
| Native (Recommended) Resolution | 1280 x 1024 | ||
| Resolutions supported | 1280 x 1024 | ||
| Resolutions supported | 800 x 600 | ||
| Resolutions supported | 640 x 480 | ||
| Resolutions supported | 1024 x 768 | ||
| Resolutions supported | 832 x 624 | ||
| Resolutions supported | 1152 x 864 | ||
| Resolutions supported | 1152 x 870 | ||
| Resolutions supported | 720 x 400 | ||
| Resolutions supported | 640 x 350 | ||
| Synchronization Range - Vertical | 56 - 75 Hz | ||
| Dimensions | |||
| Depth | 6.9 in. | ||
| Height | 15 in. | ||
| Width | 14.6 in. | ||
| Weight | 9.6 lb. | ||
| Warranty | |||
| Warranty | 3 Years | ||
