20 Most Recent
Samsung 204T 20" LCD Monitor Questions & Answers
How do i turn it on
On pg 12 of the manual indicates the Power On/Off switch is beside the power cord plug in.
Turn on the monitor one
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
When i boot my computer,
It may have dying power supply due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
I forgot my password to my computer now I can't
Turn on your computer, go into safe mode (press the F8 key on top of your keyboard). Select Safe Mode (either one, doesn't matter). From there, go into your User accounts and either delete the account and/or change the password thats all
The monitor was appearing to
More likely to be bad caps with leaking/bulging top, that will be the first thing to look for.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Only displaying 10 x 10
It sounds to me that you have the resolution on the wrong setting. Go a a clear space on your desktop, right click, and select properties. When that opens go to the settings tab and change the screen resolution to 1600 X 1200. This is the native setting for the monitor. If that doesn't fix the problem continue changing the screen resolution until you get one that works.
I turned off my pc,
Check that the video cable is seated properly and secured to the port with the screws.
My computer screen got water on it and now is
If it was "plain" water, it might dry out without leaving any residues. If it was coffee-with-sugar, or soda-pop, the sugars will cause problems.
All you can do is to let it dry out, and hope.
Samsung 204T no longer displays
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Hello, my screen shows
This happens since you are using pirated version of windows.In order to avoid this follow the below steps
1. Before doing anything serious try restoring your system. If the problem is occurring after the Windows Update then System Restore will surely help.
2. But if it does not then do try this, launch Windows Task Manager.
3. Locate the process “wgatray.exe” and end it.
4. Log in into the Safe Mode and delete the file WgaTray.exe from c:\Windows\System32
5. Also delete the WgaTray.exe from c:\Windows\System32\dllcache
6. Type regedit in Run to open Registry Editor, navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify key.
7. Delete the folder WgaLogon and all of its contents.
8. Restart the PC normally.
