20 Most Recent Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Questions & Answers
replace capacitors 1000mf/25v 470mf/25v...
Samsung... | Answered on Dec 18, 2018
Resolution setting of computer is not compatible with spec on monitor. Adjust computer res setting to agree with monitor and you will be good to go. If settings are ok then the issue lies within the innards of your monitor.
Samsung... | Answered on Apr 15, 2017
Its simple bro , Your CPU is not reading RAM,so just Remove and Re Insert the Ram to in DIMM Slot and then Switch on Computer it will work fine.
Samsung... | Answered on Jan 21, 2015
This means your computer windows resolution is not display in the correct resolution which your samsung LCD will take.
What you need to do it boot the computer in safe mode. (pressing F8 at start up and select safe mode) This should bring the windows to start up in the generic 800x600 resolution.
Once you are able to see the display in safe mode, go onto the display properties and change the resolution.
* right click on desktop -> properties -> settings
Please rate this if it solves your issue. If you need further assistance please post.
Samsung... | Answered on Mar 15, 2013
if you can hooked up with other monitor just to ensure if the problem is only with in the monitor. after you replaced with other monitor then the display is clear or good picture, that was mean the only problem is the monitor. if the upper portion is black screen or the picture not so clear the cause is busted screen back light. to see the back light you will need to remove the back cover of the monitor. then the back light is a thin cold cathode flourescent tube, it was covered with a metal shield cover protection attached at the upper portion of the screen panel display.
Samsung... | Answered on Nov 08, 2012
PLS PRESS AND HOLD ENTER UTTON AUTO LOCK WILL BE RELEASED
Samsung... | Answered on Mar 31, 2011
Here is the user manual to download taht will help you set it back to English.
http://www.retrevo.com/support/Samsung-913V-Monitors-manual/id/278ci766/t/2/
Please leave rating if it helos.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Samsung... | Answered on Jan 14, 2011
You should try this with another PC and check the video cable first.
If it still does not work then please read my guide before DIY repair.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Samsung... | Answered on Jan 03, 2011
Do one think just plug out Monitor to CPU cable , just on monitor only if so can you able to see one small icon go top to bottom its like keyboard, if you can see that, you don't have any problem on your monitor.
step 1 - just remove ram slot and insert again try to ON your system now
step 2 - take your cpu and connect to other monitor and check where it getting on or not , if monitor get ON and work good mean you don't have problem with your CPU , problem was in monitor to cpu cable ,so change your monitor cable its just cost of 4 to 5 $.
step 3 - take your monitor connect to another CPU , check weather you getting same problem if it work good mean, your CPU motherboard have problem just call your hardware engr to solve it,
GOOD LUCK ! if your problem solved don't forget to rate
Samsung... | Answered on Dec 31, 2010
The white and red wires are for sound only, you will need to connect a video source, usually a yellow wire.
What is your video source? dvd, computer, vcr, cable
Write back and i will help more
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Samsung... | Answered on Oct 03, 2010
Please try this monitor on another PC first, if it still does not work, then please read below and look at the pictures to get some ideas of what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Samsung and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Samsung... | Answered on May 08, 2010
You probably have caps failing in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Samsung... | Answered on Apr 29, 2010
The problem can be caused by bad caps in the power supply, bad inverter circuits, worst will be bad lamps. Look inside for bad caps first, report back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Samsung... | Answered on Jan 28, 2010
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
56 questions posted
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
samsung syncmaster 913v monitor will not
  • Computers & Internet
