20 Most Recent Canon MV750i Mini DV Digital Camcorder Questions & Answers
The only solution is to give it in for repair
Canon MV750i... | Answered on Apr 02, 2016
you need a head cleanner
Canon MV750i... | Answered on Sep 15, 2011
This is usually caused by a defective CCD image sensor or a defective audio/video drum and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Canon MV750i... | Answered on Sep 14, 2010
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
Canon MV750i... | Answered on Sep 11, 2010
bad battery, no battery conection, no battery found
Canon MV750i... | Answered on Mar 17, 2010
First, if the battery was connected to the unit for all of that time it is D-E-A-D. Use the AC charger for power with the battery disconnected if necessary--if everything works, its the battery.The problem is not CCD related at all if you can get an image on either display(not on a playback mode), that immediately rules out the CCD--it provides for *all* displays. However, if you can view using the LCD screen, and still can't use the eyepiece, then there is an internal problem with the unit. Camcorders and cameras don't like to be be unused for long periods of time. Internal electronic components can become defective from lack of use. If you find that your camcorder needs repair, send it directly to a manufacturer repair facility--stores add their own "handling charge" by usually halving the repair quote and then adding that amount to the bill *you* see.
Canon MV750i... | Answered on Sep 18, 2009
Hi there
Can you confirm that the battery is fully charged, or can you try recording with the power cord plugged in and see if that helps? Let me know.
If not, when you get a black screen, are you able ot browse the on-screen menus at all? Do they show up but only the recording image behind them doesn't? Let me know.
Or, do you get a completely black screen regardless of what you press?
You mention the flashing icon below the battery icon. Does it look like a boat? If so, this means that the backup battery (usually a button cell) is flat and requires replacing. This should solve the issue.
The backup battery is located behind a flap behind the actual large battery.
Best regards
nLinked
Canon MV750i... | Answered on Jul 08, 2009
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Canon MV750i... | Answered on Jun 25, 2009
This sounds bizarre I know, but I read another threat regarding Canon camcorders and tapes self ejecting. The advice was to ........ wait for it........ drop it onto a carpet floor from about 1/2m. My wife top me not to consider it. I continued reading and someone else had been successful using the technique. I have to report that it actually works. I dropped it (twice for good measure) and it loads tapes once again. Its true what they say, if in doubt....give it a clout!!!
Canon MV750i... | Answered on Jun 03, 2009
talk to canon - this is a known error and they will fix it for free
Canon MV750i... | Answered on May 04, 2009
There are 2 or 3 very small fuses on the main circuit board. These are commonly termed "Surface Mount" They are approximately 1- 1 and a 1/2mm long and only half the width. They are white on the face with a letter on them. These are fuses of which you can if you are very careful and with a fine tipped solder iron, replace.
To determine the faulty one, use a simple multi-meter and test for continuity across the fuses in turn. The fuse with an open circuit is faulty ie...does not read on the meter.
If you are silly enough to use a piece of fine wire to bridge the faulty fuse...then be it on your own hands...but remember, THE FUSE BLEW BECAUSE OF A FAULT and the wrong rated replacement could cause further failure if it is not able to "BLOW"
Canon MV750i... | Answered on Apr 10, 2009
http://www.memory-up.com/Memory/CanonMV967.html shows that the max is 512
Canon MV750i... | Answered on Dec 26, 2008
Hi.
Do you get an image come up on the tft screen or the viewfinder, when you put the 'corder in rec mode?
Canon MV750i... | Answered on Dec 10, 2008
Hi.
The CCD has gone. It is about £30 from a canon dealer in London, and about £50-£75 to replace (labour)
So, is it good enough to have it done? I've done a couple now, only because they were both presents to the owners so did not want to throw them away!
Hope this helps
Canon MV750i... | Answered on Oct 10, 2008
Flick the switch on the side of the camera just above the power switch to tape instead of memory card
Canon MV750i... | Answered on Sep 11, 2008
the vhs is an analogue output which does not allow the digital time and date to be carried over: u need a digital output
Canon MV750i... | Answered on May 30, 2008
Canon MV750i Mini DV Digital Camcorder Logo
29 questions posted
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Video Cameras
  • Canon Video Cameras
Most Popular Question
grey horizontal lines during playback
  • Video Cameras
