20 Most Recent
Canon Elura 85 DV Digital Camcorder Questions & Answers
Elura 85
I am not the person who made any suggestion to you. I happened to see your post when reading on this site.
When this type of problem ocures in any of the camcorders, this means that there is usually a mechanical fault with the loader mechanism. Another cause can be that there is a sensor fault with either a tape position sensor, or with the electronics that operates with the sensors, and the tape loader mechanism. If there is a servo fault the loader will also be commanded by the uPC to eject the tape.
Because of the way the camcorder is constructed and its sophistication, this is not something you can fix yourself. The electronics are mostly all SMD technology, and the mechanical parts are very fine as like in a mechanical wrist watch.
I would suggest that you get in touch with the manufacture service rep to arrange to have an estimate for repair. The service cost is not cheap for these types of devices. The work is time consuming and the replacement parts can be expensive. Get an estimate for service before making any decisions.
You may find that servicing your unit when it is out of warranty may not be worth the cost. If your unit is more than a few years old, you must consider that it may pay to get a new unit.
Jerry G.
I have a Canon Elura
This can be caused by several problems including a defective eject switch in the cameras internal circuitry, a stripped gear or a bad motor. This will require disassembling the camera to diagnose and repair. This can usually be done fairly inexpensively but it's not really a user serviceable problem and should be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
The tape won't eject. Do I need to send in for
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My camera reads "condensation detected"....yet it
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Cannot eject video cassette from Canon Elura 85 camcorder
Hi there , please contact with your service center. Because the cassette ribbon some how stick inside with the camera head. So i will not going to open easily. You have to open the camera outside body cover & then the cassette cabinet. After that you can clean the cassette ribbon & take out the card. Thanks & waiting for your feedback.
Wont playback videos taken
Some common faults with most camcorders and video playback units:
Dirty heads
Failure in the head assembly
Failure in the head pre-amp section
Failure in the main video processing section
Internal system timing fault
Servo lock fault condition
uPC is hung in its operation and requires a re-set
The unit should be properly checked at a service center to determine the exact cause of failure.
Jerry G.
Elura 85
Take the camcorder to an authorised service center. They will have to open the camera up and have to manualy operate the mechanics to have an ejection of the tape. Most likely there is a failure in the camera that will have to be maintenenaced.
Jerry G.
I need help!
i had the same problem, i shut the camera off, hit the cassette door a few times (not kidding) and when i turned it on it was fixed. the zoom bar will not show on the camera screen, but it won't keep zooming in by itself!! i had gotten this advice from people who had a similiar problem with the elura 60's models, must be a problem across the board.
Won't accept minidv tapes
That happened to mine. I had to take the camera back to bestbuy where I bought it and get it fixed. I forget what was wrong with it. Something on the inside got screwed up. I think it was called dubbler or something like that.
How to remove a tape out of a canon es55 that will not power up even if the battery is charged
If you suspect that your JVC camcorder may have been damaged by plugging in the wrong power cord, it's possible that the cassette mechanism may not release as intended. However, you can try the following steps to manually release the cassette:
- Turn off the camcorder: Make sure the camcorder is turned off and unplugged from any power source.
- Locate the cassette release button: The cassette release button is usually located on the side or bottom of the camcorder near the cassette compartment. It may be labeled "eject" or have a symbol that looks like a triangle with an arrow pointing up.
- Press the cassette release button: Press and hold the cassette release button for several seconds to see if it releases the cassette. You may need to press it firmly or use a pointed object like a pen or pencil to press it.
- Manually release the cassette: If the cassette release button does not work, you can try manually releasing the cassette. Look for a small hole on the camcorder near the cassette compartment. This hole may be labeled "emergency release" or have a symbol that looks like a triangle with an arrow pointing down. Insert a straightened paperclip or similar object into the hole and press gently to release the cassette.
If you are unable to manually release the cassette, it's possible that the camcorder has been damaged beyond repair.
My CANON MV940 DIGITAL VIDEO CAMCORDER cant charge.....when i plug it in the battery charge indicator does not flash or light up
If your Canon MV940 digital video camcorder is not charging when you plug it in, there are a few things you can check to try to determine the cause of the issue:
- Check the power adapter: Make sure that the power adapter is securely plugged into the camcorder and that the outlet you are using is working. Also, check that the adapter is not damaged or malfunctioning.
- Check the battery: Make sure that the battery is inserted correctly and that it is not damaged or worn out. If the battery is old or has been used for a long time, it may no longer hold a charge and will need to be replaced.
- Check the charging port: Make sure that the charging port on the camcorder is clean and free of debris. If there is debris blocking the port, use a soft-bristled brush or a can of compressed air to clean it out.
- Check the battery terminals: Make sure that the terminals on the battery are clean and free of debris or oxidation. Clean the terminals using a soft-bristled brush or a pencil eraser.
- Check the firmware: If the problem persists, check to see if your camcorder's firmware is up to date. If it isn't, update it.
If you've tried all of these steps and you still cannot charge your camcorder, it's possible that there is a hardware issue with the camera. In this case, you may need to contact Canon support for further assistance.
https://amzn.to/3WisSDI
