20 Most Recent Sony VAIO GRV550 Notebook Questions & Answers
mkv files are for HD movies that are pirated and reencoded - because of that they will run only on much better laptops than what you have: they need at least 2GB of memory and a dual-core processor.
Sony VAIO GRV550... | Answered on Jan 24, 2019
Here is step by step solution (It works most cases) 1. first of all open registry editor.( in run write regedit.exe and press Enter)
Then go to: "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\IDE"
Once you're there, you should see multiple entries for your IDE drives.
Check your CD-ROM drives. Check the entry directly below your CD-ROM drives
to see if any of them have a property for the LowerFilter or UpperFilter. If
so, delete the property. If you get a prompt saying you can't delete the
property, you'll have to modify the permissions of the registry entry so that
you're allowed to edit.
Hope this helps...
Sony VAIO GRV550... | Answered on Mar 27, 2011
We need more details like: where are you connecting your laptop to,
is it to the tv.. ect.
Sony VAIO GRV550... | Answered on Jan 21, 2009
From what I understand there may be a problem with the power circuitry used to light up a small fluorescent light that is the actual light source for the display. The TFT display itself doesn't produce it's own light, and if you point an external light source to the display and see program windows & other things the display itself is fine. Your problem can be solved with relative ease, but only in a computer service because it demands some components to be changed.
Sony VAIO GRV550... | Answered on Dec 08, 2008
Follow these steps
First you should Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
- Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing blue screen
Sony VAIO... | Answered on Feb 19, 2019
www.driverguide.com use the 2 drivers free install per day freature. it will help you for sure
Sony VAIO... | Answered on Jan 23, 2019
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sony VAIO... | Answered on Nov 30, 2018
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu?
thanks
This can be a faulty inverter or a faulty CCFL lamp. Pleaseclick on this link and follow my instructions to identify the fault andpossible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
the windows may infected by virus or gone corrupt, re-installation/recovery is suggested
Check this Sony's website:
Original Drivers Package
Sony VAIO... | Answered on Oct 09, 2018
Try to:
Open Computer by clicking the Start button and then clicking Computer.
Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
Sony VAIO... | Answered on Sep 30, 2018
If you only erased it, you can simply use the keyboard shortcut CTRL+Z, if the deletion was permanent, there is nothing you can do.
Sony VAIO... | Answered on Aug 11, 2018
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
Sony VAIO... | Answered on Jan 22, 2018
Hello -
Depending upon where (in your home?) you use your Sony Vaio laptop (via WiFi?) you may need a WiFi booster or extender. Or, you may find that moving your WiFi router to another location in your home will improve your connection without diminishing the connections for other laptops used in your home.
Perhaps the information here will prove instructive:
https://www.repeaterstore.com/pages/wifi-booster-repeater-extender-differences
Note: If the router needs to be moved in your home, you will probably need a technician for your Internet provider to come to your home to relocate it and connect it properly.
Sony VAIO... | Answered on Dec 28, 2017
Sony VAIO GRV550 Notebook Logo
Popular Tags
8 questions posted
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
dark lcd monitor
  • Computers & Internet
