20 Most Recent Sony VAIO VGN-T350P/T Notebook Questions & Answers
Finding the right translation service is hard work, if you do it on your own. But you don't have to do it. There are plenty of review sites online for translation agencies, such as Pick Writers. This information should help you make smart decisions.
Sony VAIO... | Answered on Aug 08, 2017
To start, it may be a longshot, but try turning off bluetooth, in case that is interfering with the sound, or sending the sound elsewhere, like to a bluetooth speaker or cell phone. Also, try downloading the ESET NOD32 online virus scanner using Fireofox, to rule out any pesky viruses messing with your VAIO.
If problem persists....
Open the start menu, and check around for any VAIO support software that can check your system for errors and hopefully fix them.
Open the sound icon next to the date and time on the lower right portion of the screen, and open the mixer, where you are able to see the volume for mic, speaker, and a bunch of other things. Check to see that no mute has been selected, or that no audio has been disabled.
Look inside the control panel, and find sounds and audio. When you open it, click around and see it the wrong audio device got somehow selected, or if NO audio device is selected, and go ahead and select a different device from the drop down menu to see if picking another device fixed the issue.
Next look inside your device manager, and see if the audio device shows up, and hopefully it does, then see if it has a yellow exclamation point next to it. Even if it does not, click on it, and find the option to add or update the driver for it. You may have to insert the restore DVD that (hopefully) came with your VAIO.
The next options, in case nothing has worked, are to do a full reinstall of your Windows OS, drastic but we are at that point. Or else, I have seen instances where the actual sound card in the laptop has died, which would be one reason why Windows no longer recognizes any audio device as being there.
I hope one of these fixed the issue for ya!
Sony VAIO... | Answered on Nov 08, 2013
A PC/laptop hangs when there is a clash of SW and HW. HW you can do nothing about and hence it is the SW or the operating system, ie, Windows that is at fault. It is just that some parts of the Windows OS hs got corrupted for some reason. Please re install Windows to get rid of the hanging problem. I am giving a link below for you to read, understand and follow if you have Windows XP. If other than Windows XP then you will have to do a fresh reinstall for which there is another link to be followed.
For Windows Xp http://www.informationweek.com/shared/printableArticle.jhtml;jsessionid=ZC30BJMORZQH5QE1GHPSKH4ATMY32JVN?articleID=189400897
For other Windows Saving Data After A Crashed Windows On...
Sony VAIO... | Answered on Aug 04, 2011
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Sony VAIO... | Answered on Jan 28, 2011
1.refix the battery
2.fully charge your battery till 100% without any interption
3.now you work with your laptop untll it would be the 0%.
4.Kindly repeat the steps four times.
5.After that you Defently feel,your battery backup will increase.
Sony VAIO... | Answered on Nov 18, 2010
Try going into device manager
click start
then control panel
then system
they hardware
then device manager
if there is a yellow !mark next to sound then use the properties tab to reinstall the the driver
Hope this helps
Sony VAIO... | Answered on Aug 19, 2010
Hi. Here is a graphical instruction to disassemble your laptop and replace LCD screen. http://laptoprepair.ca/news/11776.html
and here is the service manual in case you need more info.
http://www.notebook-manuals.com/laptop-manuals/service_manual_for_SONY_VaioVGN_T350P_9e406957d4_VGN-T350P-manual-repair.pdf
Good luck.
Sony VAIO... | Answered on Jun 13, 2010
Control panel/regional and language settings.
Sony VAIO... | Answered on Apr 09, 2010
it could be caused by a lot of things. isolate it first. since its randomly shutting down, try first in normal mode. does it heats up before it turns off, if yes its an overheating issue. you may need to replace fan or even motherboard of your pc. have you checked your battery? is it properly seated? or is the problem happening when your system is plugged with the ac adapter? try to check the power cable.
Sony VAIO... | Answered on Apr 06, 2010
This just happened to me too!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gor_6037a73d06938472
Sony VAIO... | Answered on Jan 30, 2010
hi, it may be a ram or processor problem you may need to replace one of them
Sony VAIO... | Answered on Jan 17, 2010
here is a search engine 'google' search to click on and check.
Many suppliers actually have 'A stock' New/most expensive or 'B-Stock' slightly used/less expensive or even 'C-stock' far more economical that may have a few scratches on them.
Which ever one of them you use - try to negotiate with their price as they may even take your broken one back!
http://www.google.com/#hl=en&q=laptop+replacement+screens&aq=0s&aqi=g-s1g-sx1&oq=laptop+replacment+screens&fp=5b7cf21b103219ea
Blessings,
A/V Media Guy.
Sony VAIO... | Answered on Nov 21, 2009
Hmmm,
Sounds very much like a loose connection from the motherboard audio out to the sound card. The onyl fix for that would be to open the laptop case and physically check the wiring. Not an easy task with modern notebooks. I take it it is out of warranty? If not then your safest option is to return it to the manufacturer ... or visit the outlet that you purchased it from.
Regards,
Ripface.
Sony VAIO... | Answered on Sep 27, 2009
Go to sony.com and look for sound audio drivers under support and driver downloads.
Sony VAIO... | Answered on Jun 16, 2009
Okay, the first place you can check is on the recovery disc if you have one. If not then you can go to the Sony website and under support and downloads you can either let the site scan your laptop or you can type in your laptop model info. The site will then provide a list of all the drivers and downloads available, as well as instructions.
Sony VAIO... | Answered on Apr 29, 2009
It is built in. Remove and reinstall the audio drivers.
Sony VAIO VGN-T350P/T Notebook Logo
33 questions posted
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
find manual english spanish translation
  • Computers & Internet
