20 Most Recent
Acer TravelMate 242LC Notebook Questions & Answers
My acer Travelmate 242lc will not power on
First think , has it been dropped, jarred, banged, .....you get the idea? Does it continue to blink, the HDD? Do you see a "ghost image" in the monitor in a bright light? Do you here sounds? You say "nothing else happens", meaning the light stops blinking? Shut down, unplug, remove battery, plug in, try to boot noemally.
Windows not starting on Acer 242lc laptop...
James,
Dont worry..we can get it fixed...if u have backup of all ur files i suggest u just wipe the disk clean and start all over agin....
ur machine will become factory fit...for burning CDs u can get Nero...i will load it on to my website...
go to my website and visit FoamtDisk page...all deatils of re-installing OS is detailed there....
www.sureshayyar.110mb.com
give me a feedback of what u did !!!
hope u have the Windows Cd with u to re-install the OS
How to change cmos battery
You are correct, the BIOS battery is flat and needs to be replaces.
The BIOS battery maybe behind one of the panels on the bottom of the laptop or it maybe under the keyboard. The most common BIOS batteries in laptops are button 3v lithium batteries. You need to locate, remove to identify the type and size of the battery.
Black screen on acer 242lc lights come on power up
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
My laptop after being turned on a blue screen appears and then shuts down
There are many reasons this can be happening. Try starting the computer in Safe Mode with Networking and see if the problem still exists. If not that means there's a problem with the start up boot process. Questions to consider: How old is the machine? Have you done all your updates? Possible virus. What exactly does the Blue Screen read? Is it a quick blue screen then restarts or does the blue screen stays? We are computer service company that offers remote free diagnosis. Call us to today at (877)608-4574 or visit us at www.aplusonsite.org.
HOW DO I DOWNLOAD FACEBOOK ON MY TABLET
I found out in Google that this tablet has Windows 8 on it.
You can install Facebook on it by going to the "Microsoft Store".
If it didn't install, check if your operating system is 8.1
Let me know if that helps.
