20 Most Recent
Apple MacBookAir A1370 -19648 Questions & Answers
Why does my gmail have lines and lines of numbers underaddress
Usually those extra lines come from HTML and plain text email conversion by Gmail's servers. There is nothing to be alarmed by, if the above is the case. Generally speaking you're likely looking at the header code of an email when such lines appear beneath your email address.
If it's causing a problem or simple annoyance you can change your preferences to not receive or send HTML email, which usually has worked for me in tackling the same problem on my own Gmail accounts over the years. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Is NTS Global Services legitimate?
NO
1. Empty cache, remove history and quit Safari.
2. Power down router and restart.
3. Download and run in scan mode AdwareMedic.
4. When all is good download and run in Safari Extensions AdBlockPlus and Ghostery.
No icons
Sounds like it may be a disk problem. Try open Disk Utility (if you can't find it, use Spotlight (press Command and Spacebar) to search for it. Repair Disk Permissions. Also, try Verify Disk.
If this don't work, or you get errors from Verify Disk, try and turn off the Mac (power down), then start up holding down the Command and R keys and you should boot into the emergency disk. Here you can Repair Disk, and then repair permissions again.
Hope this helps...
My mac doesn't turn on
Sounds like an issue with the battery, or far less likely, the power supply (which carries electricity from the battery to the various components inside your computer).
I dropped my mac lap top and the screen is a bit fuzzy, how can I fix it?
Thank for contacting Fixya, I will be glad to assist you. You cannot, without having a diagnostics performed by a certified Apple technician or Apple Authorized Service Provider. You may have damaged the video graphics card on the main logic board of your MacbookMacbook Pro.Unless you have knowledge on how to go in and physically troubleshoot this geniune hardware issue, I would recommend you do you to your local Apple retail store Genius bar, or Apple Authorized Service center near you and have your Macbook looked at.Just for your reference, I have taken the liberty to provide the store locator links to your local Apple Retail store as well as a general store locator for locating any local Apple Authorized Service center in your area.
Apple Retail Store(Genius bar - need to set appointment via this website link, if planning on visiting Apple store of choice in your immediate area)
Apple Authorized Service ProviderYou don't want to keep turning on the Macbook until you have it checked because it could affect more than just the video graphics card.Regards,-The MacTechTrainer.
I have a Sanyo Xacti 10 MP that records with date and time but when I put the SD card in my Apple laptop and download the videos, the date and time seems to not stay on the videos.
The date and time information may not be embedded in the video file itself, but rather in the metadata of the file. When you transfer the video from your camera to your computer, the metadata may not be transferred along with the video.
To preserve the date and time information on your downloaded videos, you can try the following:
- Use a video player that displays metadata: Some media players, such as VLC media player, allow you to view the metadata of a video file. If the metadata contains the date and time information, you may be able to view it using such a player.
- Transfer the video using a program that preserves metadata: Some file transfer programs, such as Image Capture on Mac, will preserve metadata when transferring files. You may try using such a program to transfer your videos.
- Use a metadata editor to add date and time information: You can try using a metadata editor, such as ExifTool, to add the date and time information to your video files.
It's worth noting that not all video file formats support metadata, so depending on the format of your video files, it may not be possible to preserve the date and time information.
How to factory reset iMac without login or keyboard?
To factory reset an iMac without a login or keyboard, you can try the following steps:
- Boot the iMac in Target Disk Mode: Connect the iMac to another Mac using a Thunderbolt cable. Power on the iMac while holding down the T key. The iMac should appear as an external disk on the other Mac.
- Reinstall macOS: Open the Disk Utility app on the other Mac and select the iMac disk. Choose "Erase" and follow the on-screen instructions to erase the iMac's drive. After erasing, quit Disk Utility and follow the on-screen instructions to reinstall macOS.
- Restore from Time Machine Backup: If you have a Time Machine backup of the iMac, you can restore the backup to the iMac after reinstalling macOS.
If these steps don't work, you may need to seek assistance from an Apple Store or a professional repair service.
I have a new MacMini 2021 Monterrey O/S. I use Zoom but my Gear Head Webcam F#2 4.8mm is not on or is not connecting? IS it compatible with Apple Monterrey O/S?
It's possible that your Gear Head Webcam F#2 4.8mm is not compatible with the new MacMini 2021 running the Monterrey operating system (macOS Monterey).
The best way to check for compatibility is to visit Gear Head website and check for the compatibility list for the webcam with the MacMini 2021 running the Monterrey operating system. If the webcam is not on the list, it's possible that it may not be compatible with the new operating system.
If the webcam is not compatible with the new operating system, it may not be able to connect to the MacMini or be recognized by the Zoom app.
Alternatively, you can try connecting the webcam to the MacMini using a USB-C adapter and see if that resolves the issue.
You may also want to check if there is any new firmware update available for the webcam or the Zoom app that might resolve the issue.
If the issue still persists, it would be best to contact Gear Head customer support for further assistance and check if there is a way to make the webcam compatible with the new operating system or if there is any other solution that can be provided.
Unlock MacBook pro
On the newer macs, you can hold down D while booting which will take you to diagnostics mode. There you can reset the password. For older systems, you will need boot media.
