20 Most Recent HP iPAQ hw6500 Pocket PC Questions & Answers
Hi, You have software problem with your ipaq. Please get it fixed at dealer .
Regards
HP iPAQ hw6500... | Answered on Feb 26, 2011
You need to examine your battery cover as one of the c hooks in your cover may be bent or broken. Basically, the hooks on the cover actually press a micro-switch that detects if the battery cover is on.
If your battery cover looks fine, then you may have a software problem. Try getting a firmware upgrade or simply doing a hard reset to see if the problem is still present
HP iPAQ hw6500... | Answered on Aug 18, 2008
If the battery was inserted to the unit prior to its storage, it might be the cause. Try charging battery directly in its cradle overnight or use new battery pack. If not then its hardware and/or formware problem. Sometimes electronic gadgets fail to work after prolonged storage due to to capacitor/condenser in its circuitry.
HP iPAQ hw6500... | Answered on Jun 02, 2008
The screen size is 240x240 so you will need to reduce your picture to that size. You can put the pictures on the storage card, or other storage and then you can go into the your today screen settings and pick the storage area with the pictures in it.
HP iPAQ hw6500... | Answered on Sep 08, 2005
I have bluetooth Activesync working on my hw6515 connected to a Dell x300. Followed the instructions in the User Guide Chapter 9. Need to take note of the com port assigned to bluetooth serial port on the PC. Connection must be initiated each time from the IPAQ ie go to buetooth manager and connect the activesync shortcut.
Hi, The Hw6500 dont have any keylock/display lock. thats why we released it with the hard plastic cover over the display, so you can have it against your ear without pressing the display all the time.
What model HP iPAQ?
HP iPAQ... | Answered on Oct 28, 2013
Yes. I'm assuming your printer has the old style Winchester plug instead of a USB jack. It's called a USB to parallel adapter or a USB to printer adapter.
HP Computers &... | Answered 19 hours ago
no pc stated, hp what? guessing laptop.
windows 10
tell what the PC does good and bad both.
boots ok.
logs in ok
desktop works OK?
my guess is you meant Accelerometer dead, or the thing called
drive Guard,
most HP pCs 10 year old fails this if you upgrade it to w10
this is the HP only software that protects the HDD if Laptop is dropped.
if the PC has SSD upgrade this software is useless.
if is real HDD, the w7 version has 50/50 chance of working.
so tell more ,get more.
HP Computers &... | Answered Yesterday
please go to hp.com and get your answer.
ok?
HP Computers &... | Answered 2 days ago
either the cooling fan on the mother board, the case or the power supply is not functioning the system will not power on properly or will shut down quickly if the fans are not running. I would guess one of the system board fans are not working and if not replaced the system will not power on or let you into windows
NO PC STATED, JUST 30 YEARS OF HP COMPUTER.
BUT is 2007 or never with w10, is it 32bit or 64bit PC and OS?
type winver in the run box to learn what you run.
or is windows dead, (unstated also)
my guess wild , is you forgot to type this.
Error Code 0xc0000001 in Windows
we first run HDD tests, after all if the OS is corrupted (per above)
then repair or fresh installs will fail on all bad or weak HDD.
so if that passes read this
https://answers.microsoft.com/en-us/windows/forum/windows8_1-update/unable-to-boot-error-code-0xc0000001-youll-need-to/520d5a3f-1fbb-4a9a-98d1-03a8201f00ed
HP Computers &... | Answered 3 days ago
HP.com has all your bios updates and info..
HP Computers &... | Answered on Jun 13, 2019
HP iPAQ hw6500 Pocket PC Logo
22 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
iPAQ HP
  • iPAQ HP
Most Popular Question
ipaq switches off
  • Computers & Internet
