20 Most Recent
Whirlpool GZ25FSRXYY Questions & Answers
NEED TO CHANGE FREEZR IGHT BULB CAN'T REMOVE BIN TO ACCESS LIGHT
Do you mean the basket that pulls out above the drawer? This is witchy to get out. You need to depress the two tabs while lifting on the entire square piece. Not easy to do but, after years of doing it I have pretty much mastered it. However, you should not need to remove the basket to change the light.
2/6/2016 10:55:27 PM •
Whirlpool...
Answered
on Feb 06, 2016
Ice maker not working
Need to check that the water valve is working properly and if it is then you probably have a bad ice maker.
7/28/2015 1:55:12 PM •
Whirlpool...
Answered
on Jul 28, 2015
Water leaking bottom refrigerator freezer drain defrost
See if you have a frigde on the techbulletin below.
Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only! https://docs.google.com/file/d/0BzIiBNwRIV4NNWJNNmx0andROGs/edit
8/26/2014 4:52:34 PM •
Whirlpool...
Answered
on Aug 26, 2014
Check the referenced technical bulletin below and see if your have a listed model number. Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only! https://docs.google.com/file/d/0BzIiBNwRIV4NNWJNNmx0andROGs/edit
8/26/2014 4:51:28 PM •
Whirlpool...
Answered
on Aug 26, 2014
No ice
What is the temp of the freezer? It has to be zero or colder, as far as, I know to freezer water. Check the water supply. Is the water turned on to the maker? Could be a faulty water valve. It's usually where the water connection is made. Is there a water filter in-line? Could it be clogged? Some filters only allow water to flow in one direction. Look for an arrow of flow on the filter. Good luck.
8/17/2014 1:42:13 AM •
Whirlpool...
Answered
on Aug 17, 2014
HOw to remove ice maker module cover
Don't bother. If your icemaker is more than a few years old, it's probably pretty cruddy and needs to be replaced, especially if you have hard water. It's an easy job and you can get OEM replacements for Whirpool from Amazon for less than $100. But before you do, you need to check the diagnostics to make sure the full bucket sensor is working properly. This varies by model, but there is usually a blinking LED in the freezer that tells you what's going on.
3/31/2014 8:03:10 PM •
Whirlpool...
Answered
on Mar 31, 2014
