20 Most Recent Goldline Cams, Set Of 2 For Gva-24 Valve Actuator - Glx-Gva- Questions & Answers
Communication error 2 means and requires what steps to correct?
See update below: Problem recurred.I have a Hayward Goldline Aqua Logic Automation and Chlorination System. Back in February, I noticed that the indicator lights were either flashing or "all on" or "all off." The LCD screen still functioned, so at least I could still operate the controls and see on the screen whether I was activating the spa spillover, spa, pool, or pool heater. I could still set the timers, etc. So I lived with that for a while, since a new PS-8 control panel isn't cheap (about $400.)A few days ago, I noticed the "Communication Err2" message and Hayward's toll-free number below it. None of the buttons responded or did anything. No beep. Nothing. I turned off the breaker, waited, and turned it back on. The pool system would reset, but then within a couple minutes, the "Communication Err2" message returned. After a few times doing that, the control panel stopped responding altogether. Even though I couldn't use the control panel, the pool filter was still automatically turning on and off at the times I had set. That probably meant the circuit board was still good, but the control panel finally needed to be replaced. So I bit the bullet and ordered it. The new PS-8 panel arrived today and I swapped it out. Voila! Everything works now. (big sigh of relief.) No more error message.12/21/2017 UPDATE: The new PS8 panel worked for about two days, then the Communication Error came back. At first intermittently, then after another day or so it was permanent; once again I couldn't use my pool controls. After a tech came to the house and said he'd have to call Hayward during business hours so they could "talk him through" a possible repair, I called a different Hayward-authorized service. That person told me to check and see if there were any remote connections plugged in; those can cause communication errors if they get shorted out. I removed the front panel of my unit and unplugged the connections for the Aquaconnect wireless antenna and for the side spa remote. The errors have disappeared once and for all. The next step will be to get a new antenna and wireless system that will work through the internet and through my cell phone.
6/20/2021 7:52:00 AM • Goldline Pool &... • Answered on Jun 20, 2021
Goldline Pro Logic freeze warning temperature
Possibly bad 10k ohm sensor?
5/28/2015 3:55:12 PM • Goldline Pool &... • Answered on May 28, 2015
2answers
LifeSmart LS350 Plus Hot Tub Jet Spa. Can I convert my LifeSmart LS350 Plus 110v to a 230V
Question edited for clarity. Question moved from Computers category. Yes if you swap everything that is connected to electricity over to 220 volts. It is marketed as a 110 volt spa eliminating the problems of running 220 volt power. https://www.google.com/search?q=lifesmart+ls350+plus+220+volt ..
4/14/2024 9:55:26 AM • Pool & Spa • Answered on Apr 14, 2024
2answers
How do you clear a general fault on the power supply of Minimax NT5000 24V/15A-HR?
Contact the manufacturer 1 800 863 3930 for specific information about this. The manual does not include information for getting rid of a general fault. https://www.alpha.com/download/outside_plant_power/cableups_power_supplies/broadband_ferro/install_oper_manual.pdf
3/17/2024 4:14:55 AM • Pool & Spa • Answered on Mar 17, 2024
2answers
My Maax 461 Spa Heater heats constant until overheat and trips out until manually reset. If jets not turned on, the heater will overheat and trip. Acts like contacts stuck?
Question edited for clarity, 'till' refers to turning over soil, 'tilling', 'until' is the word you need. That sounds like a thermostat problem. The heater should only be on when water is circulating, even if it is just in the standby mode before the high pressure jets are turned on. Contact your installer or one of the parts suppliers in the link. It is unlikely to need a new mainboard. https://www.google.com/search?q=Maax+461+Heater ..
3/17/2024 4:08:41 AM • Pool & Spa • Answered on Mar 17, 2024
2answers
What is chemistry?
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
3/17/2024 4:06:29 AM • Pool & Spa • Answered on Mar 17, 2024
I am searching for an Aristocrat manual for the spa.
https://www.manualslib.com/manual/726129/Aristocrat-Usa-Mav500-Mkvi.html
1/8/2024 4:28:34 PM • Pool & Spa • Answered on Jan 08, 2024
OH Code how to correct so Spa runs?
OH Code is Overheat, so all the things you tried are not relevant. Low flow is normally the reason, too much heat build up in the heat exchanger so it cuts out. So, the next time your spa throws you a OH, OHH or some other "overheat" error code, you know what to do. Clean or replace the spa filter, open all the jets and turn the pump on high. If you still have problems, check over your temp sensor and high limit circuits for wire, plug or sensor problems.
Spa & Hot Tub Error Codes - OH, OHH, OHS
1/1/2024 4:40:07 AM • Pool & Spa • Answered on Jan 01, 2024
Leisureite GL2000 Spa. I am looking for a new cover for it please?
Question edited for clarity, spelling of maker and order of 'make model (what it is)'. Question moved from Sewing Machines category. It appears to be a New Zealand product made in Australia. We are in North America. This link should find you one and also has a link to the maker. https://www.google.com/search?q=+leisurerite+GL2000+spa+replacement+cover ..
12/11/2023 10:27:56 PM • Pool & Spa • Answered on Dec 11, 2023
Approximately, how many hand dips would you say you get out of a 3 lb Paraffin bath?
It should be plenty and you can reuse the wax once it sets anyway. https://www.google.com/search?q=3+lb+Paraffin+bath ..
12/3/2023 6:02:24 PM • Pool & Spa • Answered on Dec 03, 2023
Motor just hums does not run.
bad start up capacitor or motor
12/3/2023 3:50:52 AM • Pool & Spa • Answered on Dec 03, 2023
How to get the outlet filter off a Stylus spa bath
It appears to be an Australian make. We are in North America, so this link might work better for you. https://www.google.com/search?q=Stylus+spa+bath+replace+filter ..
11/21/2023 4:21:42 AM • Pool & Spa • Answered on Nov 21, 2023
How to replace power cord on Intertek 4007787
https://www.manualslib.com/manual/1592331/Coleman-90403e.html?page=5#manual
11/12/2023 8:27:08 AM • Pool & Spa • Answered on Nov 12, 2023
3answers
My lazy spa has been fine for 18 months and is now tripping electrics every time I put on to heat and filter
if your hot tub is tripping the breaker, it could be due to a worn out ground fault circuit interrupter (GFCI) breaker, which is responsible for preventing electrical surges. You can try flipping the breaker to see if it trips again. If it does, then you may need to replace the breaker. Another possible cause of the problem could be loose electrical connections in your hot tub . This can lead to power fluctuations that cause your hot tub circuit breaker to trip. Professional electricians can inspect your hot tub and tighten any connections that are loose, which should fix the circuit breaker problem. If your spa is not receiving power, you should check your home's circuit breaker to ensure that it's not tripped . Reset the circuit breaker if it's tripped to restore power to the spa. If the circuit breaker keeps tripping, it may be an indication of an electrical problem, and you should call a professional electrician to diagnose and fix the issue
11/12/2023 1:21:05 AM • Pool & Spa • Answered on Nov 12, 2023
Goldline Cams, Set Of 2 For Gva-24 Valve Actuator - Glx-Gva- Logo
4 questions posted
Top Goldline Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Goldline Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Goldline Pool & Spa
  • Goldline Pool & Spa
Most Popular Question
communication error 2 means requires
  • Pool & Spa
