20 Most Recent Canon CB-2LX Battery Charger Questions & Answers
Most of the charger will support 110v / 220v automatically. Look at the label on the back of the charger to verify that.
Canon CB-2LX... | Answered on Nov 09, 2013
Hi, try to print the error/jam report for service mode, in that report you can see which sensor is detecting the jam
Canon Office... | Answered 7 hours ago
Hi, i found this , i hope it helps :The wiring is faulty (short circuit, open circuit). The separation fan (FM13)is faulty. The DC controller PCB is faulty.
If you checked every part of the printer perfectly and you are entirely sure there is absolutely no paper jammed somewhere, then please check if all the rollers run smoothly and have no blockage. If needed, put some lubricant on the spinning parts to make it go smoother. Do a test run and see if it helped.
Canon Office... | Answered 19 hours ago
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Canon Office... | Answered 21 hours ago
hi! this is Alex Walker expert to help you call me on 518-348-9393 Thank you
Canon Office... | Answered 2 days ago
Try printing in photo. Sometime the check works OK but its not enough for regular printing. I use this method when I refill cartridges because they are not made to last more than original fill.
Canon Office... | Answered 3 days ago
Hi. That error indicate a failure in the home position of the shutter of the fixing unit . Maybe dirty of loosen sensors. Remove the fixing unit and verify
Try this . Make some copies ( at least 5) and open one of the covers while machine is making copies. Remove the paper jam and verify if the copy is blurred. Do this to be sure of what unit is causing the blurred copies. If copy information is good before the paper enter in the fixing unit . That mean the problem is is the fixing unit
Hi. Paper jams all the times , or frequently? Try to print the jam log from service mode. In that log it shows the exact sensor that is detecting the jam .
Contact Canon directly to inquire.
Hi. What type of driver are you using , pcl, ps? Try using the UFRII driver type
Canon CB-2LX Battery Charger Logo
4 questions posted
Clive
Clive
old marine
old marine
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
need transformer use canon battery
  • Office Equipment & Supplies
