20 Most Recent FAIP 1500 PSI Electric Power Washer Questions & Answers
Are you talking about the electric switch that shuts off the motor when the trigger is released?
If so, there is an arm that comes out of the high pressure side of the manifold and is connected to a spring loaded piston. The piston extends under high pressure (spray trigger released) and retracts when spraying. At the opposite end of the arm is an allen screw and locknut. The allen screw bears on the microswitch arm to control the electric motor. When properly adjusted, the motor should turn off when the trigger is released. If it doesn't, loosen the locknut and adjust the allen screw slightly outwards toward the switch. Pull the trigger a few times and verify the motor starts up and shuts down when you release it. Tighten locknut.
Hope that helps.
FAIP 1500 PSI... | Answered on Jul 11, 2014
There are no parts available for the inside of the guns. All you can do is replace the gun.
see parts in link.
http://www.ppe-pressure-washer-parts.com/12POE-150-power-washer-parts
FAIP 1500 PSI... | Answered on Jun 11, 2014
Is this the one?
http://www.power-washer.us/images/stories/manuals/H150.pdf
FAIP 1500 PSI... | Answered on May 27, 2014
hi, more than likely a psc motor on a `small pressure washer.
The usual problems with the capacitors failing is down to a poor power supply, wether it be using a long extension lead of too small a size, or the power supply itself.
check voltage to machine while using it, a voltage drop will cause characteristics of motor to change, phase angles etc..
A refrigerator starting relay would not have the required amperage ratings for a pressure washer..
hope this helps , andy
FAIP 1500 PSI... | Answered on Oct 17, 2013
The water supply may be blocked. Check filters, screens, or it may be air-locked.
FAIP Garden | Answered on Jun 18, 2017
FAIP 1500 PSI Electric Power Washer Logo
Popular Tags
14 questions posted
Top FAIP Garden Experts
roeb
john h
Marvin
Marvin
Are you a FAIP Garden Expert? Answer questions, earn points and help others
View Most Popular
FAIP Garden
  • FAIP Garden
Most Popular Question
set high pressure unloader valve faip
  • Garden
