20 Most Recent Homelite For Husky - Pressure Washer Pump 2700 Psi Vertical 7/8" Questions & Answers
Not supposed to add or change oil in that model of pump. But if you must. Remove the pump from the engine. If the pump does not budge at all from the engine shaft, try penetrating oil. If even then you are able to remove it, place the pump with the legs down on a bench. Remove the three bolts that hold the wet end (water pump) on to the oil end. Then remove the four bolts under that equally and carefully. Close to the end of removing the bolts hold pressure down because there are three piston springs that will pop it off if you are not prepared for it. 80W90 full synthetic is a good replacement. But I'm not sure how much goes in them.
Homelite For... | Answered on Jun 02, 2015
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
Homelite For... | Answered on May 15, 2014
Your top seal on the mower motor is faulty...replace with new seal...
Homelite For... | Answered on Mar 31, 2013
What we normally say is good quality two stroke oil 50-1, two stroke oil from unknown manufacturers 25-1
Homelite Garden | Answered on Jul 10, 2019
The oil ratio is not adjusted to the engine it is the formulation of the oil. You mix your oil the way the bottle states. I have been working on 2 cycle engines since the 70's at a motorcycle, ATV and lawn & garden dealership. If you have doubts about a 50:1 oil do like I do and put 8/10ths of a gallon of gas in you jug and use a bottle of oil for a gallon and mix.
Homelite Garden | Answered on Jul 01, 2019
As with any brushed electric motor both brushes should be changed, it is not good practice to have different lengths of brushes.
Homelite Garden | Answered on Jun 19, 2019
you should be able to replace the bulb. take the model numbers to any mower parts store and they can get you this part.
Homelite Garden | Answered on May 27, 2019
16 to 1 There is a universal synthetic oil that works well for most all 2 cycle engines and causes less problems than standard 2 cycle oil. Also try rec 90 or rec 89 gasoline it contains no alcohol and will stay stable longer.
Homelite Garden | Answered on May 10, 2019
sounds like the needle and seat need to be replaced. the carburetor is flooding out and running in the oil. after you replace the needle and seat i would recommend changing the oil.
Homelite Garden | Answered on May 09, 2019
Always use unleaded gasoline with a pump octane rating of 86 or higher. Never use old, stale, or contaminated gasoline, and do not use an oil/gas mixture. Do not allow dirt or water into the fuel tank.
Homelite Garden | Answered on May 07, 2019
Contact Homelite directly to inquire.
Homelite Garden | Answered on Apr 29, 2019
ASK Google OR A CHAIN SAW DEALER LOCALLY . I HAVE NOT SEEN ONE OF THAT MAKE FOR MANY YEARS NEW
Homelite Garden | Answered on Apr 22, 2019
Homelite For Husky - Pressure Washer Pump 2700 Psi Vertical 7/8" Logo
4 questions posted
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
View Most Popular
Homelite Garden
  • Homelite Garden
Most Popular Question
add oil pressure pump
  • Garden
