Troubleshooting & Support
Hot Topics:
- compaq presario...
- compaq...
- cpu
- laptop fan
- 1247
- 1277 cooling...
- presario fan
- 1277
- 1246
- gateway fan
- presario 1246
- hp 530
- Fan Error
- fan turn
- dreamgear dgwii
- hp
- turn
- boot
- working
- drive
- light
- model
- screen
- presario 2200...
- hard disk
- display
- mother board...
- coolin fan
- gateway ml6720
- View All »
Problems & Solutions
have an old Compaq Presario model 1277 laptop.
press F-10 at start up the select o/s if thAt dont work press F-8 select safe
I have a Gateway Mx6440 Laptop and et CPU FAN
"Turn off computer and unplug power cord. Disconnect all external devices. Remove the battery. Press power button and hold for 10 to...
I am looking for any computer component. It should
Hi! It seems that you misunderstand how this site works. FixYa does not sell anything. FixYa is a community of independent users who share...
emachines T2958 overheating and shutting down
Your computer is automatically shutting down to prevent damage to the CPU because it is getting too hot. This can be caused due to a...
computer
If you have the original Windows operating system boot disk or can get one via download, try booting off that. If the computer then runs OK,...
screen display
It's hard to find a Compaq manual their site, but they indicate you'll find this in the help files on your computer.This is usually...
fan makes noise, labtop overheats,
Replace the fan with the bodged bearing already; also, get iPads (but you knew that bit.)
It tries to boot from the empty diskette drive and
During the boot process you will see on the screen to press delete to enter setup Press and hold delete during the boot up process to enter...
I have a compaq presario 1277. The screen has a...
Most likely.
where is clock battery in my laptop compaq
Remove the touchpad screws on the bottom of the laptop. Lift the touchpad and the keyboard. Remove the flat metal heatpipe above the CPU (3...
problem with the coolin fan
send it back to HP. Call them. Not worth voiding your new warranty.
Hello so I have a gateway labtop model ml6720 and
The most affordable is to take it to a reputable repair person or check my website www.micromendllc.com. The price of the fan is cheap but...
1247 compaq presario
Here is a link to the 14.8v rechargeable replacement here Compaq presario laptop battery , this is for the presario 1200 range of batteries...
cooling fan does not come on no power to the
So basically you cannot get the pc to POST. Meaning you have just a black screen when you power on the pc, right? First off, did you attempt...
I have a crashed compaq presario, 1247-model...
do you have a copy of windows xp with license key if so that will suffice then all you have to do is go to hp.com and download the drivers...
See all HP (158800-001) for Compaq Presario 1246, 1247, Solutions
Unsolved Problems
how to switch off the
how to switch off the laptop
Just wondering what processor I can whack in it.
Just wondering what processor I can whack in it. currently using a 400mhz, just wondering if it will support a 1ghz.
i have no sound whatsoever,
i have no sound whatsoever, and i don't know the model of my compaq laptop
I bought a used Compaq Preario 1246 today, when I
I bought a used Compaq Preario 1246 today, when I power it up the sceen remains blank, is this a problem? jim
Compaq presario 1200 power light
Compaq presario 1200 power light comes on but it doesn't do anything else?
i have a Gateway ml 6732 laptop and the cpu fan
i have a Gateway ml 6732 laptop and the cpu fan error upon boot....and it is not working
my compaq presao was frequent to crashing
my compaq presao was frequent to crashing (shutting Down) immediatly. It happened 5 or 6 times and finally the last time...
turn switch on computer but fan runs and will not
turn switch on computer but fan runs and will not turn the computer on?
ERROR msg the OLEAUT32DLL file cannot start.
I would like to fix or bypass so I can reach safe mode to eventuly restore to factory condition. PS I do not have...
i need the brand and model number, features and
i need the brand and model number, features and cost of cooling dervice be displayed clarly!
See all HP (158800-001) for Compaq Presario 1246, 1247, Problems
Manuals & Guides
TopDo you have a manual for HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan? - Upload it to FixYa!
Upload a manual for HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan
Specifications
TopProperties
Full Product Name:HP (158800-001) for Compaq Presario 1246, 1247, 1277, 1279 Cooling Fan
Product ID:23054932
Type:Cooling Fan
MPN:FD0530154B2A158800001
What's your problem?
Fix-O-Meter
7,076
7,076 people have viewed this product
- 31 people asked about this product.
- 18 people found solutions for this product.
- 0 people have added this product. Be the first!
Green is the...
