20 Most Recent Stihl Ms361 Carburettor Questions & Answers
Tank vent
Not a hard job to replace. Here is a link to the parts manual.
1/2/2015 7:23:00 PM • Stihl Ms361... • Answered on Jan 02, 2015
Fs55rc trimmer has no compression? Any help would be appreciated? Thanks
Suggest a cranckcase leak test to locate leak(s) other than rings. You need to seal the intake and exhaust ports and pressurize the crankcase via spark plug hole. No special tools other than an adapter from sparkplug hole to compressed air. The intake and exhaust ports can be sealed with pieces if old bicycle inner tube between carb and port and muffler and port. Then apply 5 to 10 psi to spark plug adapter. Spray case seams and shaft seals with WD40 or soapy water to locate slow leaks.Search "two cycle crankcase leak test" for videos.
4/2/2024 2:58:24 PM • Stihl Garden • Answered on Apr 02, 2024
2answers
Where can i buy a nylon head for a stihl fe 55 weed eater
I have been trying to find a new Trimming head for my Stihl FE 55 for about 4 years now, with no success. A British company say that their part no. 400471021932 fits my machine. I'm in South Africa but, and need to source one here.
2/6/2024 11:13:37 AM • Stihl Garden • Answered on Feb 06, 2024
Stihl 55 Blower, runs for 5 mins then bogs down and stalls. I have replaced fuel filter, fuel lines, air filter, carburetor and spark arrestor. I checked exhaust for blockages, still has the problem?
It is a fuel / air problem. Do you have a primer bulb, did you replace it and put it in the right way around arrow to the carb? It is a known issue. There are lots of help online and there are some videos below..
I have a stihl model bg 55 blower it starts fine runs for 5 ...
JustAnswer https://www.justanswer.com > small-engine > 2otj1-sti... Oct 22, 2009 - cub cadet self propelled mower starts up fine runs for about 5 min. then dies. Will start again after several pulls then dies again 4-5 min. 1 answer · Top answer: 3 real options. I will start with the easy one. 1. Your gas cap could be not venting correctly. ...
Stihl Blower BG55 Bogs Down - Arborist Site
arboristsite.com https://www.arboristsite.com > threads > stihl-blower-b... Dec 5, 2013 - It I lock it on full run eventually it works itself out within 10-20 seconds. Since it never lasts long I have always put up with it, until now. Stihl bg86 leaf blower bogs how to remove limiters? Nov 16, 2015 stihl sh85 bogs down after start- how to fix. - Arborist Site Sep 13, 2009 Stihl BG56C blower bogs when the throttle is engaged Mar 28, 2020 More results from www.arboristsite.com
Blower: Runs For A While Then Dies
eReplacementParts.com https://www.ereplacementparts.com > lawn-equipment If your blower runs for a while then dies, you'll need to check the fuel filters, spark plugs, and more. Our troubleshooting and repair guide can help.
Stihl BG55 Blower Problem!!! - Lawn Care Forum
lawnsite.com https://www.lawnsite.com > ... > ?? Mechanic and Repair May 1, 2008 - After the first couple minutes of running, the blower will normally bog down briefly and then I let off the throttle. Once I reapply the ... Missing: stalls ‎' Show results with: stalls
Stihl leaf blower- running problem
The Garage Journal https://www.garagejournal.com > forum > threads > sti... Nov 12, 2009 - I have a BG 55 when fuel tank gets down to 1/2 empty it stalls out. ... run, it revs up to max then dies completely. It will only start on full ...
11/26/2023 1:12:50 AM • Stihl Garden • Answered on Nov 26, 2023
Stihl MS 250, what is minimum compression, and what is spark plug gap
Hello again Jack! Did you fix the Ryobi? What is the minimum compression for my STIHL chainsaw? Generally the minimum is 110 lbs. of compression.
Chainsaw FAQ - STIHL
What is the correct spark plug gap for my STIHL trimmer, chainsaw, or blower? The correct gap setting is 0.020".
stihl usa https://www.stihlusa.com > ... > Products ..
11/25/2023 2:29:41 AM • Stihl Garden • Answered on Nov 25, 2023
The diagram of how to replace the throttle cable on a Stihl 55 weed eater
I'm sorry, but I can't provide a visual diagram as I can't display images or diagrams. However, I can give you a step-by-step guide on how to replace the throttle cable on a Stihl FS 55 weed eater. Before you begin, make sure you have the necessary replacement parts and tools. Materials and Tools:
  • Replacement throttle cable
  • Screwdriver
  • Pliers
  • Allen wrench
  • Socket set
Procedure:
  1. Safety First:
    • Ensure the weed eater is turned off, and the spark plug is disconnected to prevent accidental starts.
  2. Remove the Air Filter Cover:
    • Locate the air filter cover on the weed eater's engine and remove it. Typically, this involves loosening screws or clips.
  3. Access the Throttle Cable:
    • With the air filter cover removed, you should be able to see the carburetor and the throttle cable attached to it.
  4. Disconnect the Throttle Cable:
    • Carefully disconnect the throttle cable from the carburetor. This might involve loosening a screw or bolt holding it in place. Note how it is routed and attached.
  5. Remove the Handle Housing:
    • Locate the throttle trigger on the handle housing and remove it. This may involve unscrewing parts of the housing or loosening screws to access the cable.
  6. Replace the Throttle Cable:
    • Feed the new throttle cable through the handle housing and reattach it to the throttle trigger. Make sure it's properly connected.
  7. Reconnect at the Carburetor:
    • Reattach the other end of the throttle cable to the carburetor in the same manner it was originally connected.
  8. Adjust the Cable Tension:
    • Adjust the cable tension to ensure it operates smoothly. There should be some slack when the trigger is released but no excessive play.
  9. Reassemble the Weed Eater:
    • Reattach the air filter cover, making sure it's secure.
  10. Connect the Spark Plug:
    • Reconnect the spark plug and ensure it's properly seated.
  11. Test the Throttle:
    • With all the components reassembled, test the throttle to ensure it's working correctly.
  12. Start the Weed Eater:
    • Reconnect the spark plug and start the weed eater. Verify that the throttle is responsive and functions as expected.
This is a general guideline for replacing the throttle cable on a Stihl FS 55 weed eater. Keep in mind that specific models may have variations in their design and components, so refer to the user manual or consult with a professional if you encounter any difficulties during the replacement process.
10/18/2023 5:43:01 AM • Stihl Garden • Answered on Oct 18, 2023
Stihl FS55R running issues
Tom, Check out this Video... https://www.youtube.com/watch?v=1a7E6PPQv3c Best to you.
8/28/2023 8:27:27 PM • Stihl Garden • Answered on Aug 28, 2023
I have a battery powered Stihl weed eater. A piece of twine is stuck in the housing. How does that get removed?
I use an EGO 56 volt battery trimmer and did this the other day. I lost one end of the line inside after trimming along a brick wall. Under the spool they where two plastic tabs. I pressed them in and the top popped off. I removed the line and put the top back on and added new line as per instructions. https://www.google.com/search?q=battery+powered+Stihl+weed+eater+remove+spool+top ..
8/18/2023 5:18:13 PM • Stihl Garden • Answered on Aug 18, 2023
Stihl TS350 Concrete Saw goes at full throttle with the choke full on, when I let go of the trigger she stops. Can any one help on this.
It needs a good servicing as this is a Vintage Saw. This has a diaphragm carburetor, so the first place to look would be there and a torn diaphragm. Good place to start here https://www.madontools.com/gas-cut-off-saws/stihl-cut-off-saws/stihl-ts350-cut-off-saw/ https://www.google.com/search?q=stihl+ts350+service+manual https://www.google.com/search?q=Stihl+TS350 ..
6/12/2023 12:16:52 AM • Stihl Garden • Answered on Jun 12, 2023
Stihl fs38 line trimmer fuel line diagram
Easy way to figure it out without a diagram. Connect the filtered fuel line from the tank to either port of the carburetor. Leave other carb port open. Press purge bulb several times. If the filtered line is connected to the correct carb port, fuel will spurt out the open carb port. No fuel, switch filtered line to the other carb port and repeat purge to verify correct connection.
Warning, NEVER use the unfiltered fuel line for this procedure.
5/22/2023 9:18:59 PM • Stihl Garden • Answered on May 22, 2023
How do I replace the throttle on my fs38 Stihl weed eater
To replace the throttle on a Stihl FS38 weed eater, you'll need to follow these steps:
  1. Disconnect the spark plug wire to prevent accidental starting.
  2. Locate the throttle cable where it connects to the carburetor and carburetor housing.
  3. Use pliers to loosen the lock nut on the carburetor side of the throttle cable and slide the cable out of the carburetor and carburetor housing.
  4. Replace the throttle cable with the new one, feeding it through the carburetor and carburetor housing and tightening the lock nut on the carburetor side with pliers.
  5. Check the operation of the throttle by starting the engine and confirming that the throttle cable moves freely and the engine speed changes accordingly when the throttle is manipulated.
  6. Reconnect the spark plug wire.
It's recommended to consult your FS38's user manual for specific instructions as the process may vary slightly based on the model. download (2)-undefined-undefined-1_2.jpg download (2)-undefined-undefined-2.jpg
2/8/2023 6:32:30 PM • Stihl Garden • Answered on Feb 08, 2023
3answers
I have a STIHL BR600 BLOWER and the choke switch is loose and will not stay in the position set
A very simple solution to r epairing all by yourself is getting help from hand books, they're very detailed and complete in every way so for me it was my best source to repair one of the top sites for this is https://big-manuals.com/
1/25/2023 9:16:04 PM • Stihl Garden • Answered on Jan 25, 2023
Best way to replace chain oiler line on a 036 stihl saw
To replace the chain oiler line on a Stihl 036 chainsaw, you will need to follow these steps:
  1. Disconnect the spark plug wire to prevent the chainsaw from starting accidentally.
  2. Drain the old chain oil from the oil tank.
  3. Remove the old chain oiler line from the chainsaw.
  4. Clean any debris or blockages from the oiler hole.
  5. Cut a length of new chain oiler line to the appropriate size. The line should be long enough to reach from the oil tank to the oiler hole on the bar.
  6. Attach one end of the new chain oiler line to the oil tank and the other end to the oiler hole on the bar.
  7. Secure the line in place with the appropriate fittings and clamp.
  8. Fill the oil tank with the recommended type and amount of chain oil.
  9. Reconnect the spark plug wire and test the chain oiler to ensure it is functioning properly.
It is important to use the correct type and amount of chain oil to ensure the chainsaw operates properly and to extend the life of the chain and bar. If you are not comfortable performing this repair yourself, it is recommended to have a professional chainsaw repair technician handle the repairs for you. Regenerate response
1/6/2023 9:27:24 PM • Stihl Garden • Answered on Jan 06, 2023
How to adjust the points on a stihl 041 chainsaw
Different saw but likely the same for ignition.https://www.manualslib.com/manual/1040630/Stihl-009.html?page=32See adjacent pages for timing and armature edge gap.
12/30/2022 11:15:18 AM • Stihl Garden • Answered on Dec 30, 2022
3answers
Can't get my Stihl weedeater to start/stay running without holding down the throttle
If it only works at full throttle it sounds like this is a fuel supply issue. Are you getting hard start issues? When was this weed eater last given a full service? A clogged fuel line, Clogged fuel/air filter or and old spark plug can have a bigger effect than you think. Bad, old or wrongly mixed fuel can also affect how the engine will run. (Stihl recommend a 50/1 mix on 2 strokes). Modern fuels go 'Bad' after a few months leaving a varnish like coating inside the fuel system. You often get this if it is stored over the winter with fuel in it. The carburettor could also need cleaning as well. If you have no experience working on small engines or carburettors your safest option is to get a specialist repairer to look at it for you. Servicing small engines like these is usually quite cheap as it is usually only one spark plug, a foam air filter and a small amount of engine Oil.
12/29/2022 8:08:14 AM • Stihl Garden • Answered on Dec 29, 2022
2answers
My chainsaw dies or seems as if it chokes out while i am cutting. Any ideas why? I have a STIHL MS 170
You are probably running it too rich. Try leaning out the high speed jet a little. That's the one closest to the air filter. Out to the left, in to the right. Out richens, in leans. Too lean = cooked piston, so be careful. If you really screw it up, take it to a STIHL dealer.
11/23/2022 6:20:38 PM • Stihl Garden • Answered on Nov 23, 2022
What champion spark plug is used in a stihl ms 170 chainsaw
RCJ6Y at 0,5mm (0.020 in) gap.
11/21/2022 11:23:10 PM • Stihl Garden • Answered on Nov 21, 2022
2answers
Stihl 391 chain saw chain not getting oil
remove your bar and chain. check now for oil. also at this point clean and inspect the oil hole on your bar. if you get oil from unit with bar and chain off then the problem is in your bar. if still no oil and assuming you have oil in reservoir then remove clutch and oiler cover remove the worm gear and inspect. if damaged replace if not with low pressure used compressed air through to resevior
11/13/2022 7:49:38 PM • Stihl Garden • Answered on Nov 13, 2022
I have a Stihl BR340 backpack blower that won't start.
check to see if the key way on the crankshaft to the magneto is not stripped. if the key way is stripped the timing will be off and it wont run.
10/20/2022 4:00:57 AM • Stihl Garden • Answered on Oct 20, 2022
Stihl Ms361 Carburettor Logo
1 questions posted
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
View Most Popular
Stihl Garden
  • Stihl Garden
Most Popular Question
tank vent
  • Garden
