20 Most Recent Hobart Quantm1-1ss Quantum Self-service Scale Questions & Answers
All LCD displays have a connector from the main board, and it may also be ON the main board, and may have a long, special connector that is layers of silicone and conductive material that connects the back of the glass display with the connection points on the PC board.
When one of these points is not connected, you can get a blank line or a dark line on the display. Either way, you have to take the front panel off and try a few things. Sometimes just disconnecting and reconnecting the display connector is all that is needed. In the case of the silicone connector, the screws or clips that hold it together need to be loosened, the connection moved, and then re-tightended.
In the case of an intelligent display, there will be just a few wires, as few as 5 or so. In this case, the fault is in the display itself, and you have to get a new LCD display.
Hobart... | Answered on Jun 12, 2014
There is no ink. It has a thermal printhead.
Hobart... | Answered on Jan 10, 2014
sounds like it is setup to print a secondary label. go into supervisor mode 10 and check to make sure the secondary label setting is at 0
Hobart... | Answered on Aug 23, 2013
This happened to me:
I used a gel rust remover with an electric pad sander (3 times - with a medium course paper the first 2 times, and then a finer course paper the 3rd time). It smoothed and cleaned it up pretty darn good, but there was still a slight red discoloration to the metal. So, we just kind of line the hopper with heavy duty aluminum foil and line over that with 2 clean plastic food grade bags. Also, now as part of maintenance/cleaning after use, we use a little spray rust remover at the beginning of the cleaning process. This should help prevent any more rust and might even help dull that red discoloration after a while.
Good luck.
Hobart Kitchen... | Answered on Jan 17, 2018
Request this information directly from Hobart.
Hobart Kitchen... | Answered on Dec 26, 2016
You should be able to purchase a conversion kit from Hobart Direct or a Hobart Agent. The conversion should be done by a Licensed Gas Fitter.
Hobart Kitchen... | Answered on Oct 03, 2015
The oven has a 3 try electronic spark control. It sounds like the flame sensor is not sensing the flame correctly and is locking out. I don't know if your model senses flame through the high voltage spark wire or if it has a separate flame sensor wire.
Hobart Kitchen... | Answered on Nov 30, 2013
The is something called a duty cycle and if you exceed that rating then you have to wait for it to cool off to use it again.
Hobart Kitchen... | Answered on Oct 14, 2013
Hobart Quantm1-1ss Quantum Self-service Scale Logo
Popular Tags
10 questions posted
Top Hobart Kitchen Ranges Experts
Alan Chouinard
ka4iup
ka4iup
Are you a Hobart Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Hobart Kitchen Ranges
Most Popular Question
scale print extra label
  • Kitchen Ranges
