20 Most Recent HP Pavilion Ze4805us Notebook Questions & Answers
yes, sounds like your system board is ka-put. (bad).
HP Pavilion... | Answered on Dec 27, 2013
c drive should be free of softwares ensure that. furthermore few clean up tips are Firstly either press the windows sign with R simultaneously or click the start button on the left lowermost corner
Then a small window opens up . in the window type any one of the below and press enter. Another window opens up now single left click on any of the window contents and then press ctrltab from your keyboard with "A" tab of the keyboard. This is a shortcut to select everything in the window. Then delete all. Repeat the process for all the links detailed below this will speeden up your pc
%temp%
Recent
Prefetch
Cookies
temp
HP Pavilion... | Answered on Sep 16, 2012
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
HP Pavilion... | Answered on Aug 19, 2012
http://www.insidemylaptop.com/disassemble-asus-k-series-notebook/
This is the K series but should be the same for your model
HP Pavilion... | Answered on Jul 03, 2012
Hello Carmen, Hi, If the brightness control won't do much, looks like the LCD back lamp an/or the LCD inverter module is going bad. eventually you won't see anything on the screen. Make do of the screen for now, until the lamp/inverter fails or replaced in advance. make the most out of it. You need it serviced by a technician or the dealer.
HP Pavilion... | Answered on Feb 01, 2011
Most laptops vary teh speed of the porcessor as needed, as a power saving measure. Less speed uses less power.
When the laptop is idle it drops the speed and increases as more is needed.
HP Pavilion... | Answered on Dec 03, 2010
Hello.
The most common reasons are the power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
HP Pavilion... | Answered on Aug 30, 2010
Try connecting an external USB keyboard.
If that does not work, then it's time to contact HP, and order a replacement motherboard, or to purchase a brand-new notebook, or, if the product is still under "warranty", to make a warranty claim, to get HP to fix it, at their cost.
HP Pavilion... | Answered on Jul 19, 2010
yes, after looking up your laptop on hp's website, I have determined the kind of memory you need; (assuming your computer is the one you put in the question, HP Pavilion ze4805us Notebook PC)
you need 2x 512 mb, 200-pin, DDR 266 memory
I looked and found some Corsair (highly respected company in computer memory) memory, for 22.99 for each DIMM (you'll need to buy 2); see link below.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145482&cm_re=ddr_sdram-_-20-145-482-_-Product
If you have any more questions, please let me know!
Thanks,
Mike
HP Pavilion... | Answered on May 16, 2010
Most likely it is either a bad lcd inverter, due to the fact that you have clear picture on an external monitor. The inverter reduces the voltage coming from the motherboard to a lower level in order to power the lcd and the backlight. If this goes bad then you either get a picture randomly, a dim picture, or no picture on the lcd.
HP Pavilion... | Answered on Feb 07, 2010
If your hard drive is dead, (no hard drive found), you're going to have to have a new one (hardware) installed before you can re-install the OS and drivers (software). I doubt that you'll be able to retrieve data from the dead hard drive short of herioc (and expensive) measures.
Sorry - hope you were backing-up your data frequently.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "Very Helpful" rating from everyone I help.
Thanks for using Fixya.com,
Jon
HP Pavilion... | Answered on Dec 29, 2009
Hello, Jessie.
There is a hidden Administrator account that is created when your operating system is installed. Access that account and add your own account.
1. Boot your computer and press F8 repeatedly
2. Access Safe Mode
3. Key in “Administrator” in Username, with no password.
4. Go to Control Panel, then User Accounts
5. Create your account.
Hope this helps
HP Pavilion... | Answered on Nov 27, 2009
please change it with the same type.
HP Pavilion... | Answered on Sep 24, 2009
check the internet settings in internet explorer and check that there are no proxies set, also use another computer to check that there is an internet connection
HP Pavilion... | Answered on Sep 19, 2009
unplug the batter from your notebook and ac adapter. hold the power button for 20 seconds and plug in the ac adapter and see if it boot if it works
HP Pavilion... | Answered on Sep 18, 2009
insert the os disc in some cases systems come with a system recovery disc if this is not the case just insert what you have shutdow your system when your system boots press the del,f2,or whatever hotkey your system uses to enter the bios menu then while in bios go to boot devices or boot options and click start from cd and then press f10 to save and exit your system will ask yes no click yes then it should restart and a white text should appear saying boot from disc ? click any button when os finnally loads it will ask you to install or to repair ?click repair this searches your system finds out what it's lacking and reloads it .this should be it hope this helps good luck
HP Pavilion... | Answered on Aug 03, 2009
HP Pavilion Ze4805us Notebook Logo
Popular Tags
50 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
pc keeps saying not responding
  • Computers & Internet
