20 Most Recent Husqvarna 125B Blower Questions & Answers
Remove spark plugs and rotate fly wheel by hand - if it wont rotate piston may be seized - may need rebuild.
Husqvarna 125B... | Answered on May 19, 2019
you might have a particaly clogged fuel filter,or sucking air at the carb to motor.
Husqvarna 125B... | Answered on Feb 17, 2016
needs a proper carb adjustment for starters
Husqvarna 125B... | Answered on Oct 20, 2013
Both screws start at 1 turn out....Adjust High speed till it 4strokes and 2 strokes usually 1/8 turn either way....then adjust idle so it revs staight up...should be same 1/8 turn either way from start...if it is more carby will need overhauling..
Husqvarna 125B... | Answered on Oct 16, 2013
This isn't the most technical sounding answer but it works and I've used it numerous times with no problems. To set the coil gap on small 2 cycle equipment , I use a 3" x 5" note card, tighten the bolts then manually turn the flywheel to make sure it doesn't rub.
Husqvarna 125B... | Answered on Aug 08, 2013
There is a special tool required as the screw heads are splined, base settings are 1 1/2 turns on both, it should run at this, the L screw will adjust fuel flow from idle to half throttle, the H screw will control the fuel to full rpm.
If the engine struggles to pick up, unscrew L screw a further 1/4 turn, or more until it picks up cleanly.
Now at full revs, gently screw the H screw in until engine sounds sweet, if it starts to die unscrew to achieve full revs.
Husqvarna Garden | Answered Yesterday
From memory, the breather is in the top of the tank, you would need to remove the tank to access it.
Guide bar and chain off.
Top cover off.
Two screws and air filter off
Remove two 10mm nuts and filter back plate off
Remove throttle rod
Remove two 7mm headed screws securing carb
Remove two cross head screws from carb bracket
take carb off, remove fuel hose
Remove 4 screws securing starter, note 2 m5 and 2 self tapping, must go back in the same position on re build.
Remove chain catcher screw, and top l/h screw, these 2 are into the anti vib rubbers chain side.
The tank should now come away with top handle still connected.
Breather is in the top of the tank, it is a small white plug, some also had a duck bill valve.
Husqvarna Garden | Answered 2 days ago
It really depends on where the noise is coming from, however from your description of the sound, I would say it was a belt slipping in the pulleys, either from the engine pulley or the gearbox pulley, it could also be a seized idler pulley, check the belt manually to see if it appears loose.
Husqvarna Garden | Answered on Jun 18, 2019
The 266 has a 4 position adjustable pump, top l/h corner of the pump housing is a screw, be carful as the screw is plastic, at 90 degrees to the screw driver slot is a line on its face, the pump body is then marked 1 to 4, turn the screw to aline this line to the appropriate setting, 4 being the highest flow.
Husqvarna Garden | Answered on Jun 14, 2019
Most likely the PTO switch but could be other. You can test with multimeter or a simple automobile test lamp or just replace as they are relatively inexpensive ($10-20).
You might try twisting the switch and see if it re-engages the clutch... a sure sign the switch is failing.
See page 3 of repair parts manual.
http://service.webec.husqvarna.net/documents/HUSI/HUSI2018_NAenNAes/HUSI2018_NAenNAes_115808096_2018-04.pdf
The PTO clutch is powered from the A1 (accessory 1) terminal of the ignition switch via the PTO switch. Check for power or lack there of at the PTO electical connector and work way back through PTO switch and ignition switch.
If you have disconnected the earth cut out wire, and there is still no spark then the new unit is bad, was this a genuine part or an after market unit? either way you need to get another preferably genuine unit.510115605
Husqvarna Garden | Answered on Jun 11, 2019
Husqvarna 125B Blower Logo
13 questions posted
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
need clearance specs coil flywheel
  • Garden
