20 Most Recent Miele Cat Dog Plus S511 Bagged Canister Vacuum Questions & Answers
The first step is to remove the cover and pull out the motor at the casing of the unit.you can see the carbon brash when the motor is out of the casing.Just remove the spring and pull out the carbon brash and replace new carbon brash.Then return back the motor to the casing.Thanks...
Miele Cat Dog... | Answered on Aug 21, 2011
you can download it here. It covers many more models than just your cat and dog plus.
Good luck.
Miele Cat Dog... | Answered on Nov 19, 2010
I suggest checking the filter. If it's coming from the HEPA filter area, the filter might be out of position or possibly you have the wrong kind of filter. Miele uses 2 different types of HEPA filter so that could be the problem.
Miele Cat Dog... | Answered on Sep 20, 2009
Sorry, but the short answer is: no!
Miele Cat Dog... | Answered on May 01, 2009
Good afternoon Kristen.
Vacuum cleaners usually pop the 'bag full' indicator when they lose suction due to the load of dirt in the bag impeding the motor pulling air through.
If you are still getting the indicator with a new bag, and already did the prudent re-seating of the bag, the next thing is likely a clog or blockage elsewhere in the vacuum. You don't specify the model, so I can't be too specific.
Safety first. Please please please make sure the unit is unplugged before you start disassembling.
As you are able, detach hoses, look in the back of the brush unit, see if there's a blockage. Wads of crumpled paper are particularly good at wedging themselves into corrugated flex lines. Depending on location, I've found that a wire coat hanger, bent into marshmallow-roaster configuration, with the old hook bent with some pliers into a long straight section with a small half-loop at the end, can be a good probe for the long sections of tube to see if it runs into anything, and then perhaps hook it and pull it out. Be careful if you do this to not hook the tubing walls and tear them.
Hoping this helps!
D
Miele Vacuums | Answered on Sep 18, 2019
Check for clog. They turn off when clogged to protect motor. Do you have suction from hose, can you see through wand. Or you may have pulled cord away from cordwinder which would probably need to be replaced.
Miele Vacuums | Answered on Jul 16, 2019
Most likely a bad circuit board or it could be a bad motor. Take it to your local Miele dealer for repair or replacement.
Miele Vacuums | Answered on Apr 30, 2019
Torsion spring ? Take it to your local Miele dealer for assistance.
Miele Cat Dog Plus S511 Bagged Canister Vacuum Logo
11 questions posted
Top Miele Vacuums Experts
Colin Stickland
Colin Stickland
Gerry Harvey
Gerry Harvey
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Miele Vacuums
  • Miele Vacuums
Most Popular Question
given
  • Vacuums
