20 Most Recent Troy-Bilt 4 Cycle Straight Shaft String Trimmer TB575EC Questions & Answers
Troy Bilt TB575EC cutting head hard to load, now doesn't spin.
Remove the cutting head spool and see if you have old grass stuck around the shaft area that could be causing to cease your shaft..
3/3/2018 2:25:02 PM • Troy-Bilt 4... • Answered on Mar 03, 2018
Troy bilt 4 stroke trimmer tb575ec won't run at high rpms. it starts, but dies when throttled up. only 2 months old, added fresh gas, checked oil, did not see adjustment screws on carb?
Hi jim gabrielSounds like you have dirt/debris in your caburetor jets,fuel passages Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.Note:Before you disassemble the carburetor:Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.That way you will know which way it goes back together when you reassemble it.Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.Check you fuel line condition after a while they will degrade and need replacment.Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.Be sure to mark the turns down on a piece of paper.That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.Note:The little spring inside of the carburetor goes under the float arm.That is where your fuel inlet needle/float valve is located...on the arm at the end.Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.Once you have your carburetor cleaned/rebuilt that should solve your problem.Please take time to rate me Bud
3/4/2017 7:52:41 PM • Troy-Bilt 4... • Answered on Mar 04, 2017
Gas dripping out of air intake on troy bilt trimmer TB525EC
The diaghrams in the carb could be starting to stiffen up holding the needle open. Does it start with no choke when cold? Rebuild the carb to replace stiff diaghrams
10/27/2012 12:33:40 PM • Troy-Bilt 4... • Answered on Oct 27, 2012
Troy-Bilt pressure washer runs great until you start spraying the water through the wall and it will run it shuts off after a couple minutes how do I fix it
Inspect the seals, connections and hoses, and seals for any leaks. Leaks can lead to a drop in pressure and cause the pressure washer to shut off.
8/15/2023 6:51:28 AM • Troy-Bilt Garden • Answered on Aug 15, 2023
The Troy-Bilt 2410 snow thrower won't start. I've followed the starting procedure. Do you have any suggestions?
Check spark plug is clean and not cracked . If you google make and model it comes up with some information of how to sort problems .
12/17/2022 8:37:02 PM • Troy-Bilt Garden • Answered on Dec 17, 2022
My Troy-Bilt Self Propelled Lawnmower Wheel Not Turning on Grass
Hi, Please pour some oil on the axel of the lawn mower wheel before attempting to use it on the grass again. If this fails again, it might be time to upgrade your lawnmower. Thank you.
11/11/2022 1:39:10 AM • Troy-Bilt Garden • Answered on Nov 11, 2022
Troy Bilt Garden Tiller. How do I remove a wheel pin that is frozen on a Troy Bilt tiller please.
Question edited for clarity. Question moved from Cars and Trucks. There are lots of ideas here. I would use some Penetrating Oil and punch it out. Or you can use some heat. https://www.google.com/search?q=remove+a+wheel+pin+that+is+frozen+on+a+Troy+bilt+tiller ..
3/7/2022 12:18:46 AM • Troy-Bilt Garden • Answered on Mar 07, 2022
2answers
I have a troy-bilt 12AG839E711 lawnmower and it won't start it's getting fire but can't start it manually
You have spark but it will not run?
So could be fuel or compression or timing.
As a test, remove air filter and spray a short (1/2 second) burst of starter fluid directly into carburetor. Then promptly pull the recoil starter.
If it runs for a few seconds and stops, then it's a fuel issue. Likely fouled carburetor.
If it does not run then it could be flooded, low compression, or timing.
8/2/2020 5:53:22 PM • Troy-Bilt Garden • Answered on Aug 02, 2020
I have a Troy-Bilt Super Bronco 4-cycle weed wacker motor runs great but the trimmer head does not spin can anybody tell me how to fix it
does engine bogg down if so try clearing any grass /debris around shaft --- greasing shaft --check for damage shaft or head
4/23/2020 10:18:47 PM • Troy-Bilt Garden • Answered on Apr 23, 2020
Were to plug charger in on a Troy-Bilt Self Propelled Lawn Mower Model 12AG839E711
read all instructions before operating your mower that will include where the port is this is your manual https://www.troybilt.com/en_US/prior-year-models/troy-bilt-self-propelled-lawn-mower-model-12ag839e711/12AG839E711.html
4/12/2020 7:46:26 PM • Troy-Bilt Garden • Answered on Apr 12, 2020
How do I tell the difference between Troy-Bilt 9528 (2005-2) and (2005) If it is serial number ware is it located?
The detailed model number is 11 characters. The snow blower number is at lower left rear. See following link.
https://www.troybilt.com/webapp/wcs/stores/servlet/DisplayContentView?storeId=10001&catalogId=14102&langId=-1&identifier=PARTS_Parts&pageName=header%2fFAQ%2ffindModelNumber.html
1/19/2020 1:08:27 PM • Troy-Bilt Garden • Answered on Jan 19, 2020
Troy-Bilt 4 Cycle Straight Shaft String Trimmer TB575EC Logo
13 questions posted
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
kwfordguy
Level 1 Expert
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
View Most Popular
Troy-Bilt Garden
  • Troy-Bilt Garden
Most Popular Question
troy bilt tb575ec cutting head hard
  • Garden
