FixYa.com
HP OfficeJet 710 InkJet Printer
All Products > HP > Printers
Problems with HP OfficeJet 710 InkJet Printer?
Search inside HP OfficeJet 710 InkJet Printer Knowledgebase
Troubleshooting and Support
Solved Problems for HP OfficeJet 710 InkJet Printer RSS Feed Post a New Problem
Hooking up my Hp officejet 710 All in one
HELP!! I've never hooked up a All in One before! What needs to be plugged in to it! and how? I need to fax something for...
1 Solution
no manual
i recently received a 710 from a friend, it works fine, but i can not setup the fax/date-time functions, because i have...
1 Solution
piece has fallen out of printer
Help! I long, thin piece of plastic has fallen out of my printer. It has a hole on each end, and I can see hooks on...
1 Solution
canon iP 1300
i have a new canon printer iP 1300. the problem is that the paper wont feed. please help.
1 Solution
printer start up
just recieved printer (epson stylus c62) dont have cd install cd.but need to install.how
1 Solution
changing used toner cartridge
I need to change the used toner cartridge, and I have never done that, nor do I know how to get to it.
Post a Solution
alarm
when i try to print the printer will print about 10 letters then completely stop and the alarm light will turn on. ive...
Post a Solution
View All
Unsolved Support Problems
Unsolved Problems for HP OfficeJet 710 InkJet Printer RSS Feed Post a New Problem
hp officejet, printer copier and fax
won't connect properly and is not lised as a printer on the drop down for adding printers---i did a test print and it...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Technology (Detailed)Inkjet
Max Resolution (Color)600 x 300 dpi
Black Print Speed5 ppm
Max Resolution (BW)600 x 600 dpi
Color Print Speed2 ppm
Technical Features
Form FactorDesktop
Monthly Duty Cycle999 and less (Low Output)
Monthly Duty Volume830 Pages
Language SimulationPCL 3
Media
Media TypeTransparencies · Cards · Glossy Paper · Greeting Cards
Total Media Capacity150 Sheets
Multifunction Features
Copying Speed (Black)2 ppm
Scanning Features
Scanner TypeSheetfed Scanner
Warranty
Warranty1 Year
Dimensions
Depth14.18 in.
HP Contact Information
Main support number800-474-6836
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
