20 Most Recent
HP DeskJet 610cl InkJet Printer Questions & Answers
I hit print & the paper runs through but
I suggest that you go to HP website, download latest version of your printer driver. Install it. It sounds like your printer driver is having issues...possibly partly overwritten by other software?!?!
HP Deskjet 610CL
This is the resume button. If it is blinking and the power light is steady and if just installed a print cartridge, make sure the cartridge is securely snapped into the printer with the arrow aligned with the dots on the top of the printer cartridge cradle.
Close the top cover of the printer if it is open.
Check the lower (IN) tray to make sure it contains paper and that the paper is correctly loaded in the tray.
Press resume to clear the error condition. Then check your computer screen for any reported error message and corrective action instructions.
If the resume and power lights are blinking - press the power button to turn off the printer. At the computer, cancel any documents awaiting printing. Then press power button again to turn on computer. Good luck from Lady Isobel.
Cord to hookup printer
I don't think your printer has USB capabilities.
You need a USB to Centronics Printer Cable.
Won't print
This relates to the problem with Driver. Uninstall all the printer driver for this Printer and then restart. After that reinstall all the drivers. your problem must be solved.
How to reset HP ink ADVANTAGE 3515 Printer
Hello. First of all I would like to wish everyone a Happy New Year!
I recently bought a HP Deskjet Ink Advantage 3515 printer. The printer works fine (prints, scans and copies). There is only one problem with it. It returns me an error when I'm shutting it off. This happens very often but not always, it is kinda annoying. The error is displayed as: ERROR CODE 0X02B7C2ED SM_MODULE C (the error is also shown on the image). I tried to Google the problem but without effects. I don't know what could be the problem. Can someone help me please, because I have no idea what could be the issue. Thanks for any replays.
How do I fix an Hp deskjet 4615 not printing black?
If you are using a Windows PC, search for devices and printers. Once you find the printer, right click on it, go into printing preferences and you should find a tab in there that will all you to disable color.
If you want to be able to print in both and black will not print, make sure your black ink cartridge is not empty or that it is properly installed.
My printer cutting text from the right side when printing .HP deskjet 2050 J510
Check the paper size settings to match the loaded paper. This would happen (for example) if you have loaded A4 paper but your driver is set to print on letter format. Letter is wider than A4 by 6mm and while the printer is trying to print near to the right side, assuming the paper is wider, part of the ink goes on the paper support. Other reason may be the paper size in the document is set to be larger than the loaded paper format and driver prints only what can be fit on the loaded paper.
I have error 0xc19a0023 in my printer hp deskjet 3520.I replaced new cartridge but it isn't correct.What should I do?
1) Open the printer cover and wait till the carriage moves towards the middle.
2) Force press the printer's Power button to turn it off. Remove the power cord from the back of the printer.
3) Remove the print cartridges and place it on a small sheet with the nozzle plate facing upward.
4) Slightly wet a cotton swab with distilled water. Clean the face and edges of the face cartridges with the swab.
5) Wipe the underside of the print cartridge cradle walls using a swab. Reinsert the print cartridges.
6) Close the printer cover. Connect the power cord at the backside of the printer.
How do I scan multiple pages to one file using a deskjet 2512 printer/scanner
On the control panel, select scan to computer and choose PDF.
If you are using the sheet feeder, it will scan all pages and create one file with them all.
OR
If you're using a scanner glass, i.e. one page at a time, when the first page finishes scanning, you will get a message asking if you have another - answer YES and follow the instructions (basically that means place next page on scanner glass and hit OK/Continue). Rinse and repeat until you've scanned all pages then answer NO.
You should find a PDF file in your HP Scan Folder usually named "scan.pdf" unless you've changed the settings. (If there is/are already scanned files in that folder, they will have consecutive numbers, e.g. "scan001.pdf" "scan002.pdf" etc
10/11/2018 10:24:24 AM •
HP DeskJet...
Answered
on Oct 11, 2018
