HP Color LaserJet 4500n Printer
Problems with HP Color LaserJet 4500n Printer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for HP Color LaserJet 4500n Printer RSS Feed
Click here to get instant support from our best Experts!
View More Results for HP Color LaserJet 4500n Printer
Questions and Unsolved Support Problems
Unsolved Problems for HP Color LaserJet 4500n Printer RSS Feed
Answer
i opened the cover door to check on a paper jam. i took out the cartridge and now not able to put it... (More)
Answer
I have a scanner/printer Photosmart C400 that suddenly stopped printing, the page goes through... (More)
Answer
I have an HP Color Laserjet 4500n and the half-circle roller unit does not rotate. The printer... (More)
Answer
When I send a batch to be printed just 4 - 6 come out looking good, the rest look like the machine... (More)
Answer
I have change ITB with two other I have in working HP4500, check and verify OHT sensor, lift the... (More)
Answer
my HPC4500 series printer worked fine when first hooked up, then we went to wireless router, worked... (More)
Answer
The printer has only two trays that we use. tray 2 is for normal 8 1/2 paper and when the print... (More)
Find a Manual
HP Color LaserJet 4500n Printer Manuals & Guides
WikiManual
(Post a New Chapter)
Inkjets and Laser Priners, Inks, Toners,...
Using recycled ink cartridges in your ink-jet printer is never a more economical way to do colour printing, unless you are willing to become a master... by Soulvisitor
How to Refill and Reuse a Printer Cartridge
Printer ink is one of the most expensive things that you'll run into when you set up your home office. You start out taking dozens of pictures with... by wikihow
How to Cut Printing Costs on Inkjet Color Printer
With all of the color printing that people do nowadays, its hard to find ways to print inexpensively. There are ways to reduce printing costs on... by wikihow
How to Check if Your Printer Has Run out of Ink
Have you ever wondered if your printer has run out of a colour? Here's a simple way to check. Steps: 1. Go into Microsoft Word. 2. Create four small... by wikihow
Lexmark All-in-One x3350
'Resetting' your Lexmark x3350 All-in-One So I tried using my Lexmark today... the power button is constantly on, and it won't do anything, My... by TTonyTigger
Upload Manuals
Tips & How To Guides for the HP Color LaserJet 4500n Printer
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Canon ImageClass MF3240 paper jam fix
The Canon ImageClass MF3240 continues to show "paper jam" error even if someone followed all the possible fix to remove the jam. After... written by virtualhost
How-To Save hundreds of dollars by using all the toner in your HP-2550...
Most laser printers on the market today use a computer chip to tell the printer/computer when it's empty. The chip does not have any kind of physical... written by cococay
Printer Purchasing Tip
My tip is when you go shopping for a new printer, don't look at the printers, look at the ink cartridges. Find a ink cartridge your comfortable... written by ServicePro
How to refill the INK Cartridge ?
How do i refill my INK Cartridge ? There are 2 distinct method 1) Black has a bladder 2) Color contains sponges - we need 3 sirenges with needle to... written by tejodharatre
How to solve the print cartridge errors ?
After you install a print cartridge, the attention light begins toflash red. The printer will not print. One of the following messagesmay appear on... written by tejodharatre
Reset Waste Ink Absorber Canon i550
The following procedure is used to reset waste ink counter Canon i550. PROCEDURE: I. Enter Service Mode: Plug in power cable Hold down... written by xanda
How to clear the ink system failure error message
Hello, The "Ink System Failure" error is causes by air in the ink feed tubes. We have step by step instructions for purging the air from the... written by buddymc
How to reset an HP printer waste ink tank aborber (only work on certain...
Press and hold the ?left arrow? key. Press the ?Setup? key and release both keys. Display should say ?Enter Special Key Combo? Press and release the... written by machadojr_fe
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for HP Color LaserJet 4500n Printer
Nationwide | 8008369287 | Website
Celebrating 14 Years Of Outstanding Printer Repair And... Read More
Featured Listing
Nationwide | 972-907-9771 | Website
Printronix, IBM, Tally, Genicom, TallyGenicom, Dig... Read More
Featured Listing
Nationwide | 9185835483 | Website
Elite printer Services, Inc. is a full service HP & L... Read More
Featured Listing
Nationwide | 800-786-0288 | Website
Accram is now one of the largest nation wide mai... Read More
Ratings for the
Find a Warranty
Specifications for HP Color LaserJet 4500n Printer
Key Features
Platform
PC
Type
Workgroup
Technology (Detailed)
Laser
Max Resolution (Color)
600 x 600 dpi
Black Print Speed
16 ppm
Output Type
Color Printer
Max Resolution (BW)
600 x 600 dpi
Color Print Speed
4 ppm
Technical Features
Monthly Duty Cycle
20,000 - 49,999 (Small Workgroup)
Media
Media Type
Transparencies · Envelopes
Total Media Capacity
400 Sheets
Networking
Networking Type
Print Server
Warranty
Warranty
1 Year
Dimensions
Depth
22.46 in.
Height
15.37 in.
Width
19.7 in.
Weight
112.01 lb.
HP Contact Information
Main support number800-474-6836
Describe your problem:
Printer Ink & Toner
HP Color LaserJet 4500n Ink
Save up to 76% on
Limited Time Offer:
Additional 10% Off All Products.*
When you use coupon [WINTERTEN] at checkout
Free Shipping on all U.S. Orders over $50
*exp 03.31.2010 excluding OEM ink
Top Printer Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
