20 Most Recent HP LaserJet 2100tn Printer Questions & Answers
No duplex for this model, the only way to print on both sides of the sheet is to do it manually.
HP LaserJet... | Answered on Aug 25, 2011
I am afraid that you will not find driver for this printer because of its age. One solution would be to install on a PC where you installed Windows XP enable printer sharing
HP LaserJet... | Answered on Apr 07, 2011
Check the fuser for physical damage
HP LaserJet... | Answered on Dec 06, 2010
These are all standard cables, you will be able to get one from say Radio Shack, You need a USB 2 cable, one end is the usual USB flat connector the other is a small square one.. Look under "Printers" in the USB cables, selection, you will get one there I am sure. If in doubt ask the nice people behind the counter.
HP LaserJet... | Answered on Feb 24, 2010
A lot of people soon forget to "rifle" the paper before placing it into the bay. This helps prevent the paper from sticking during feeding. Just treat the paper like a book, and flip through the pages.
HP LaserJet... | Answered on Jan 15, 2010
HP Support says “If the Ready light is blinking, and the Go light is on, it indicates Data in the printer memory is waiting to be printed. Pressing the GO button prints from Tray 1 or from another tray if Tray 1 is empty and the paper size is supported in the other Tray. Pressing the JOB CANCEL button cancels the current job and the printer returns to ready.
Make sure the paper size is correctly defined.
HP LaserJet... | Answered on Dec 05, 2009
Thank you for your assistance. The problem was fixed following your advice.
Robert.
HP LaserJet... | Answered on Oct 15, 2009
I found the manual on the manufacturer's site, and I just followed the instructions. Thanks!
HP LaserJet... | Answered on May 08, 2008
Guys, its easy.. I found a little piece of paper after seeking calmly. It was on the paper pulling system when collecting from the tray. See the pic, it was right whee i'm pointing with my tool. It was locking one of the sensors around there. See in the third image where my tool is pointing.. Its exactly inside and very difficult to see.. And one more thing.. You'll have to unscrew the upper cover to see it.. Good luck
I love smart gadgets like this. Easy to solve. 1d69ed0c-5731-4c6b-ae7c-d49ff90e96d8.jpg 8e1e42b8-3851-411a-98e1-09eb08d019b9.jpg dd6af869-4bf3-4193-af33-57d2d362752b.jpg
HP LaserJet... | Answered on Jun 30, 2019
Go to printer driver make sure you've have legal selected
HP LaserJet... | Answered on May 21, 2019
Need more info. What exactly is happening when that error occurs? ie.. the print job starts and paper feeds through then the error pops up? etc.?
HP LaserJet... | Answered on May 16, 2019
Scanner Error 22
Is it all the colors? Make sure the drum shutters open and close when opening and closing the front door. Missing magenta color is common in this machine and other machines like it. The magenta laser scanner mirror sits in the lower part of the printer and face up and toward the front of the printer. Loose toner from printing tends to settle on this mirror. Over time the mirror coats over and the actual laser scanner beam cannot reflect off the mirror with proper intensity, usually resulting in very faded magenta color or no magenta at all. Good luck
HP LaserJet... | Answered on Apr 20, 2019
Transfer Belt Error Error code 59.FO. Replace the belt.
Don't confuse with 59.CO which is a machine problem, usually related to develop disengagement assembly. If someone has previously worked on it, then all it may need is a main assembly removal and replacement, with replacement being done to HP specs. (gear alignment and so on)
the squeal may be due to the fact that the paper tray won't lift...the lift tray should give just a bit. make sure there is not something under the tray where it won't go down. and if it doesn't go down, then the pickup roller can't rotate, and you get the noise. best answer with info. given
HP LaserJet 2100tn Printer Logo
Popular Tags
14 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
turn
  • Office Equipment & Supplies
