20 Most Recent HP LaserJet 8150n Printer Questions & Answers
By left side I assume you mean the fuser side. There are tabs on the left door that activate optical sensors in the printer body. Best option is to find a copy of the manual so you can see where the sensors are and either find a way to fix the door or jimmy the sensors. Please keep in mind that most of these sensors not only ensure that the doors and panels are closed, but shut down power to those sections to make it safe when printer is open. Find the manual here Feedroller HP Feed Rollers Printer Parts HP Laserjet Feedrollers
HP LaserJet... | Answered on Mar 10, 2015
Might be page size mis match> Check paper size in system as well as in printer.> Remove tray &check for paper size.> Clean paper path sensors.
HP LaserJet... | Answered on Dec 18, 2011
Hi there.
Here is how you do it:
  1. Press the MENU button until the display reads CONFIGURATION MENU
  2. Press the ITEM button until the display reads SERVICE MESSAGE = ON/OFF
  3. Select OFF*
  4. Press SELECT to save
  5. Turn printer off
  6. Hold the VALUE MINUS and ITEM MINUS buttons while turning the printer back on Hold buttons down until display reads RESET MAINT/COUNTand then release both buttons.
Let me know if this works or not.
thank you!
HP LaserJet... | Answered on Aug 09, 2011
62.0 memory error. This error indicates that the memory that is soldered to the formatter is likely bad. If the error was 62.1 or 62.2 that would indicate that the memory in one of the upgrade slots was bad. The only real solution to 62.0 will be to replace the formatter.
HP LaserJet... | Answered on Jun 13, 2011
If the printer isn't intializing then you may have a formatter issue. Try reseating the the formatter in the back of the printer. There is two thumb screws that hold it in place. If the printer is booting up and you can still print to it but you just can't read the control panel then the problem is with the control panel.
HP LaserJet... | Answered on Sep 01, 2010
27 Tooth Gear
hope this helps, if so please mark FixYa!!
HP LaserJet... | Answered on Jul 31, 2010
wow if you were an hp certified tech you would know instantly that 50.1 is LVPS also if you were or were not certified you could look at serv man and figure it out right quick
HP LaserJet... | Answered on Mar 08, 2010
The 50.1 error is caused by the fuser assembly not getting hot. The part you need is called a maintenance kit, it comes with the fuser and all of the pickup rollers needed to keep the printer in good shape. We have the kits available for $125 plus shipping. You can contact us at 318-447-9040 or at tech@ccl-la.com if you need to place an order. The kit will also include a PDF version of the service manual for this printer.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
HP LaserJet... | Answered on Mar 03, 2010
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
HP LaserJet... | Answered on Nov 25, 2009
HP LaserJet 8150n Printer Logo
42 questions posted
Clive
Clive
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp 8150n error code 62 0 reseated memory
  • Office Equipment & Supplies
