20 Most Recent
HP DeskJet 9650 InkJet Printer Questions & Answers
The red light and the green light stay on. They
Ours did the same thing. There is a switch that malfunctions - if you open up the back you'll see a connector with 4 metal springloaded pins on the removable back section, that matches up to a little plate with four metal bits in the back of the printer.
The bit of circuit board with the pins on gets loose in its moorings I unscrewed the removable back section and used some bits of business card type cardboard between the circuit board bit and the plastic casing to wedge it more securely in place. Now it works - good luck with yours!
The top of the cradle that holds the black ink
Since this is a Deskjet 9650 which mean it is already an obsolete printer. HP might not be manufacturing the parts anymore. Or if they did, it's so much better if you call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts, you can actually get a brand new printer half the price that you will see on the website plus you can also get an extra year of warranty just by adding $1.00 to the total price of the printer.
Hp 9650 printer. no power
Welcome to Fixya
Try to use a different power adapter with same voltage just to make sure that there is no problem with the power adapter. You can test the power adapter also by using a volt meter. See if it is givng you the correct voltage output.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Hp9650 deskjet do not have
Hello
OK, you will be able to download thew drivers at the link below. Just remember to download the driver for your specific operating system. Hope this can be of help.
Click
HERE to navigate to download page.
Kind regards
Andrea
Ink cartridges are stuck on the side and do not
The mechanism that "pulls" the heads from side-to-side could have broken.
If that's the case, it's cheaper to REPLACE the printer than it would be to take the printer to a qualified technician to try to REPAIR it.
My hp deskjet 9650 is
Hello
In this case USB cable connection is required, your printer should have a connector for a usb cable on its back.
The instructions for installing this printer with windows 7 are posted on this page
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01796821
you may try the above with the old cable, but you may have to obtain a usb cable, it will not cost more than a few dollars, or euros, depending on your currency.
you will most likely require a USB A - B cable.
The carriage on my HP DeskJet 9650 is stuck on the
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SHOWS PAPER JAM AND WILL NOT PRINT
Try reseting it meaning kill the power for an hour or so then re start it plugged in. If nto it is the geas, that are almost impossible to fix.
