20 Most Recent
HP DeskJet 5850 InkJet Printer Questions & Answers
Has anyone ever gotten this printer attached to a wireless network?
you know, I have a 2710 hp wireless AIO, and it is really crappy wireless. As far as the "detailed" manual says, you can connect wirelessly via an ad-hoc, or one to one mode. But this knocks out you're current wireless network. Example, I can't print and surf with Ad-hoc. You should however be able to connect to the wireless network though. I can with mine. But only if it isn't secure. Anyhow, look online for hp's utilities, or maybe something thats already in your programs.
HP 5850 Top Cover Open error message
There is a sensor that tells if the cover is open or closed, and a plactic "tongue" protruding on the cover, usually near the hinge, that goes into a recess in the printer.
Two things may have happened - this "tongue" broke off at some point, or the sensor developed a fault.
There are optical sensors, where the "tongue" blocks light going in between an emitter and a receiver, and simpe electrical contact sensors, which open or short when the "tongue" goes up.
There's not much that can be done with an optical sensor, but an electrical one can be inspected and corrected if needed, if you have some manual skills.
My HP 5850 inkjet has
If the printer appears to print but there is no print or images on the paper then
most likely the cause is the print head nozzles are blocked with dried ink
and inserting new ink cartridges won't fix this problem. You need a new
print head.
Print heads are not cheap, you may be better putting your money towards a new printer.
Hi I was given an hp 5850 desktop printer with no
That is all you need to start printing. You do not need to pay further as you can download the required drivers for free from HP website.
The following link will take you to HP support website where you can download the XP 32 bit driver.
HP Deskjet 5850 Full Feature Software and Driver (27 MB)
Just download the file and double click to run it. During installation it will ask you to connect the printer, do that and it will complete and let you print.
In addition to above I recommend you bookmark the following link in case you need to search for drivers and support material in future.
HP Deskjet 5850 Color Inkjet Printer
My deskjet 5850 is not printing properly. I would
go to printers & Faxes in control Panel
Right click on your printer
Choose printer preferences
Click the Services tab.
Click Clean the Print Cartridges .
Follow the instructions that display on the screen
Hpdeskjet5850printer but no driver disk to
Go here, select your OS and download drivers and software.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=305980&lc=en&cc=uk&dlc=en&lang=en&cc=uk&submit=%C2%BB
It will never shut after I install new cartridge
I had the same problem and fixed it by pushing a damp q-tip (wet and squeeze out excess) into the recess where the little triangle from the righthand side of the cover fits into the base. It's not way back, under the hinge, but more towards the front. Don't know (or care) if it was the pressure or cleaning the sensor there that did the trick.
Still cannot use my hpdeskjet 5850 printer because
No Worries!
Click this link below to select the correct operating system of your printer.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=305980&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Don't worry HP Software is for free just download and install..
I have a stuck power button on an HP 5850. It is
Try using a needle to pop the button back up. If this fails then most likely the spring for the button has failed and you'll have to use your new parts. Another method is to tap the button with a teaspoon handle lightly several times.
Paper size
try turning off the printer and computer and restarting both and see if this solves it and on the computer if this doesn't work, change the paper type in the printer's program
