20 Most Recent HP LaserJet 2420d Printer Questions & Answers
Install a hp2420 printer
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:-http://welcome.hp.com/country/us/en/support.html
3/11/2012 4:37:51 AM • HP LaserJet... • Answered on Mar 11, 2012
2answers
I want reinstall, thank you
go to printer and faxes right click and uninstall than if you replug the printer it should automatically reinstall the drivers.
3/2/2011 4:00:57 AM • HP LaserJet... • Answered on Mar 02, 2011
Lines across paper when printing after changing to
ensure that u r using a hp cartidges
dis problem persists when u r nt using hp cartidges or u have rifilled the cartides
also sometimes when the printhead of the cartideges is defective u face same problem
1/5/2011 7:34:39 PM • HP LaserJet... • Answered on Jan 05, 2011
My printer is telling me to load tray e plain
Load the paper in the appropriate tray and then press the green "GO" button. This should clear the error. If not let me know so we can resolve this issue.
9/30/2010 4:27:27 PM • HP LaserJet... • Answered on Sep 30, 2010
I want the set up of printer
A "Getting Started Guide" should come with each product. You can download the manual if you do not have one, here:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00224567/c00224567.pdf
12/7/2009 3:42:00 AM • HP LaserJet... • Answered on Dec 07, 2009
3answers
Need instructions on cleaning rollers
most likely its the fuser. There is burnt toner on the fuser and its damaged
10/31/2009 11:12:32 AM • HP LaserJet... • Answered on Oct 31, 2009
HP LaserJet Pro MFP M130fw. Error code 58.04 Laser jet pro mfp m130fw
Question edited for clarity and toss in a load of CAPS. Question moved from 'Jet Office Equipment' category. It's not good!
HP Color LaserJet Pro MFP M477
Printcopy.info https://printcopy.info > brand=HP > code=58 Code: 58.04; Display: 58.XX Error, Turn off then on; Description: The product has experienced an error with the low voltage power supply. Missing: M130fw. ‎' Show results with: M130fw.
58.04 printer display error on powerup
HP Support Community https://h30434.www3.hp.com > td-p Aug 2, 2018 - THE ERROR CODE PROBLEM OF MOTOR POWERSUPPLY BOARD (SMALL DAUGHTER BOARD TOP OF THE SCANNER UNIT), Transistor no of 905,903 like ..before you change check motor ... My printer is displaying, "58.04 Error power outage detected... Jun 28, 2022 Laserjet Pro 400 MFP 451dn error message 58.04 Aug 5, 2013 My laser jet MFP M477fdw printer is showing 58.04 error cont... Sep 22, 2021 HP M451 Error 58.04 - HP Support Community - 5830295 Nov 1, 2016 More results from h30434.www3.hp.com Missing: M130fw. ‎' Show results with: M130fw.
Error Codes > HP > LaserJet Pro MFP M130 > Code 58.XX
Printcopy.info https://printcopy.info > brand=HP > code=58 Code: 58.XX; Description: The product has experienced an error with the low voltage power supply. • 58.04 = Low voltage power supply malfunction; Remedy: 1. ..
1/13/2024 5:59:42 AM • HP LaserJet... • Answered on Jan 13, 2024
13.B2.D3 laserjet 4555 mfp keeps happening
4/24/2023 5:38:52 PM • HP LaserJet... • Answered on Apr 24, 2023
LASERJET M1212NFMFP HAS A PROBLEM OF PRINTING BLANK IDONT WHERE THE PROBLEM IS
Checkthe laser unit shutter
1/28/2023 8:54:23 PM • HP LaserJet... • Answered on Jan 28, 2023
2answers
How solve hp laserjet P1108 error
11/21/2022 10:29:05 PM • HP LaserJet... • Answered on Nov 21, 2022
Hp laserjet p2035 Attention light is ON continuously
I thought your printer have a technical issue. After resetting the toner and restarting the printer, still printer light blinked continuously. That means the printer has some other technical issue. Find here the reasons and solutions to fix the HP Printer lights blinking error.
10/28/2022 8:41:17 AM • HP LaserJet... • Answered on Oct 28, 2022
Hp laser jet printer 2055 ,52 scanner error how can solve it please
The HP Printer error 52 indicates with scanner. When you see the HP printer error code 52, then follow the steps: ·Turn off the printer ·Wait for 30 seconds and then turn on the printer ·In case the 52 error is still coming up on the printer, then make sure that the Flatbed scanner assembly is replaced ·In case the error is still being shown, the Scanner/Laser assembly may also require replacement. Find the more HP printer error codes and their solutions. If you need any help to fix the issue contact HP Printer experts.
9/23/2022 11:13:31 AM • HP LaserJet... • Answered on Sep 23, 2022
2answers
My Hp laserjet 600 m601 says 50.22.11 fuser error, how do I fix it
Replace the fuser assembly
9/20/2022 6:37:51 AM • HP LaserJet... • Answered on Sep 20, 2022
HP LaserJet pro color MFP M276N Network lan port no working
Troubleshoot the wired network connection Make sure you are using an undamaged Ethernet cable, check for a green light near the Ethernet port on the printer, and then print a report to verify the connection. Turn off the printer, and then disconnect the Ethernet cable from the router and the printer. Check the cable for damage, and then verify that it is an Ethernet cable and not a phone cable. NOTE: Ethernet and phone cables look similar, but Ethernet cables are usually bigger and have eight visible wires on the connector. Reconnect the cable to a different Ethernet or LAN port on the router, and then connect the other end to the printer's Ethernet port. Turn on the printer. Check the lights on the printer's Ethernet port to make sure the connection is successful. The green light should be steady, and the orange activity light should blink. Print a Wireless Network Test Results or Network Configuration report. Inkjet printers with a control panel menu: Open the Wireless, Network Settings, or Setup menu to locate the list of available reports. Most inkjet printers without a control panel menu: Press the Wireless and Information buttons at the same time, or press the Wireless and Start Copy Black buttons at the same time. LaserJet printers: Press and hold the Wireless button for 10 seconds or until the Ready light blinks, or go to the Wireless menu and select Wireless Network Test. Laser NS and Neverstop Laser printers: Press and hold the Resume and Wireless buttons for 3 seconds. DeskJet 6000 and 6400, ENVY 6000 and 6400, and Tango printers: Touch and hold the Information button until all control panel buttons light up, and then touch the Information and Resume buttons at the same time. Make sure the Network Status is Ready, or follow any instructions to resolve network issues identified on the report. Regards, Rachel Gomez
9/20/2022 6:31:08 AM • HP LaserJet... • Answered on Sep 20, 2022
3answers
How to clear memory on HP P3015
Before starting, note down the IP address if its network printer.. 1. Turn the product off. 2. Turn the product on. When the memory count begins, press and hold the OK button. Continue holding down the OK button until all three product control-panel lights flash once and then remain on. This might take up to 10 seconds. 3. After the message SELECT LANGUAGE appears on the display, press the button or the button until COLD RESET is highlighted. 4. Press the OK button. The product performs a cold reset and then continues its power-on sequence. 5.Chk & set I/O settings..if required..
9/16/2022 8:54:41 PM • HP LaserJet... • Answered on Sep 16, 2022
Hi, I have a HP Laserjet P3005dn printer that gives a "13.20.00 jam inside rear bin" error message. Paper has been removed and problem still persists. Please help
After removing the paper jam, the issue has still persisted, then you need to check the printer drivers. Sometimes, when you remove the any stuck from printer. Then you need to check the printer drivers. Sometime outdated printer drivers may cause of paper jam issue. Read the following methods to fix the printer paper jam issue
9/5/2022 8:41:04 PM • HP LaserJet... • Answered on Sep 05, 2022
2answers
How to change the language settings from chinese to english in hp printer m1218nfs
Press Menu button..one time Press " >" arrow button seven times, Press enter, Again press enter. Go to English language with help of arrow buttons, to save the language press enter..
8/3/2022 9:08:05 AM • HP LaserJet... • Answered on Aug 03, 2022
HP LaserJet 2420d Printer Logo
Popular Tags
7 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
install hp2420 printer
  • Office Equipment & Supplies
