HP OfficeJet 7140xi All-In-One InkJet Printer
Problems with HP OfficeJet 7140xi All-In-One InkJet Printer?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
HP OfficeJet 7140xi All-In-One InkJet...
Troubleshooting and Support
Solved Problems for HP OfficeJet 7140xi All-In-One InkJet Printer RSS Feed
View More Results for HP OfficeJet 7140xi All-In-One InkJet Printer
Questions and Unsolved Support Problems
Unsolved Problems for HP OfficeJet 7140xi All-In-One InkJet Printer RSS Feed
Answer
The HP officejet 7140xi scanner worked fine before the "scanner failure" message appears.... (More)
Answer
wont print states relacement when new cartridges are installed
Answer
Message panel says bad printhead and magenta (square print head) needs replacing? Could this problem... (More)
Answer
Just got this printer and every time I ask it to copy it says Supply expired, Printing stopped... (More)
Answer
help window says "supply expired. printing stopped. replace black ink cartridge." but I... (More)
Find a Manual
HP OfficeJet 7140xi All-In-One InkJet Printer Manuals & Guides
WikiManual
(Post a New Chapter)
Inkjets and Laser Priners, Inks, Toners,...
Using recycled ink cartridges in your ink-jet printer is never a more economical way to do colour printing, unless you are willing to become a master... by Soulvisitor
How to Refill and Reuse a Printer Cartridge
Printer ink is one of the most expensive things that you'll run into when you set up your home office. You start out taking dozens of pictures with... by wikihow
How to Cut Printing Costs on Inkjet Color Printer
With all of the color printing that people do nowadays, its hard to find ways to print inexpensively. There are ways to reduce printing costs on... by wikihow
How to Check if Your Printer Has Run out of Ink
Have you ever wondered if your printer has run out of a colour? Here's a simple way to check. Steps: 1. Go into Microsoft Word. 2. Create four small... by wikihow
Lexmark All-in-One x3350
'Resetting' your Lexmark x3350 All-in-One So I tried using my Lexmark today... the power button is constantly on, and it won't do anything, My... by TTonyTigger
Upload Manuals
Tips & How To Guides for the HP OfficeJet 7140xi All-In-One InkJet Printer
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Printer Purchasing Tip
My tip is when you go shopping for a new printer, don't look at the printers, look at the ink cartridges. Find a ink cartridge your comfortable... written by ServicePro
How to refill the INK Cartridge ?
How do i refill my INK Cartridge ? There are 2 distinct method 1) Black has a bladder 2) Color contains sponges - we need 3 sirenges with needle to... written by tejodharatre
How to solve the print cartridge errors ?
After you install a print cartridge, the attention light begins toflash red. The printer will not print. One of the following messagesmay appear on... written by tejodharatre
Reset Waste Ink Absorber Canon i550
The following procedure is used to reset waste ink counter Canon i550. PROCEDURE: I. Enter Service Mode: Plug in power cable Hold down... written by xanda
How to clear the ink system failure error message
Hello, The "Ink System Failure" error is causes by air in the ink feed tubes. We have step by step instructions for purging the air from the... written by buddymc
How to reset an HP printer waste ink tank aborber (only work on certain...
Press and hold the ?left arrow? key. Press the ?Setup? key and release both keys. Display should say ?Enter Special Key Combo? Press and release the... written by machadojr_fe
Press and hold the '*' key on the key pad, then press the '#' key and release them both. Then enter '123' to enter maintenance mode. Press the right... written by machadojr_fe
How to setup a wireless printer on Windows OS
Step 1 Go to printer setup (printers and faxes,printers depending on windows edition) Step 2 Right click your mouse on the white background then left... written by reitann
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for HP OfficeJet 7140xi All-In-One InkJet Printer
Nationwide | 8008369287 | Website
Celebrating 14 Years Of Outstanding Printer Repair And... Read More
Featured Listing
Nationwide | 972-907-9771 | Website
Printronix, IBM, Tally, Genicom, TallyGenicom, Dig... Read More
Featured Listing
Nationwide | 9185835483 | Website
Elite printer Services, Inc. is a full service HP & L... Read More
Featured Listing
Nationwide | 800-786-0288 | Website
Accram is now one of the largest nation wide mai... Read More
Ratings for the
Find a Warranty
Warranty Information for HP OfficeJet 7140xi All-In-One InkJet Printer
Specifications for HP OfficeJet 7140xi All-In-One InkJet Printer
Key Features
Platform
PC, Mac
Type
All-in-One
Technology (Detailed)
Thermal Inkjet
Max Resolution (Color)
4800 x 1200 dpi
Black Print Speed
22 ppm
Output Type
Color Printer
Max Resolution (BW)
2400 x 1200 dpi
Color Print Speed
18 ppm
Technical Features
Form Factor
Desktop
Connectivity Technology
Cable
Duplex Printout
Standard
Monthly Duty Cycle
1,000 - 9,999 (Individual)
Monthly Duty Volume
5,000 Pages
Language Simulation
HP PCL 3 Enhanced
Memory Card Compatibility
Multimedia Card · Memory Stick · SmartMedia · Secure Digital (SD)
Media
Media Type
Transparencies · Envelopes · Cards · Labels · Iron-On Transfers
Max Media Size
Legal (216 x 356 mm, 8.5 x 14")
Total Media Capacity
400 Sheets
Multifunction Features
Copying Speed (Black)
22 ppm
Zoom Range, Enlargement
400 %
Zoom Range, Reduction
25 %
Copy Speed (Color)
18 ppm
Scanning Features
Scanner Type
Flatbed Scanner
Scanner Resolution
1200 x 4800 dpi
Faxing Features
Modem Type
Fax Modem
Fax Speed
33.6 Bps
Fax Features Supported
PC Fax · Delayed Faxing · Speed Dial · Color Fax · Automatic redial · Auto Fax Reduction · Distinctive Ring
Networking
Networking Type
Print Server
Data Link Protocols
Ethernet
Memory
Installed RAM
32 MB
Max Memory
32 MB
System Requirements
Operating System
Apple MacOS 9 · Apple MacOS X · Microsoft Windows XP Home Edition · Microsoft Windows 98 SE · Microsoft Windows 98 · Microsoft Windows 2000 · Microsoft Windows ME
Warranty
Warranty
1 Year
Dimensions
Depth
16.3 in.
Height
15.8 in.
Width
21.9 in.
Weight
32.4 lb.
HP Contact Information
Main support number800-474-6836
Describe your problem:
Printer Ink & Toner
HP OfficeJet 7140xi Ink
Save up to 76% on
Limited Time Offer:
Additional 10% Off All Products.*
When you use coupon [WINTERTEN] at checkout
Free Shipping on all U.S. Orders over $50
*exp 03.31.2010 excluding OEM ink
Top Printer Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
