20 Most Recent
HP LaserJet 3700n Printer Questions & Answers
Display says Redializing...
If the display reads "reinitializing" but does not come to ready, your first troubleshooting step is to disconnect any USB or Network cables attached to the printer and restart the printer. If you still get the error, then likely the formatter on the printer is bad.
Printer error 59.99
59 error is often a motor error ;but on this machine when it is followed by 99,then it is something with the secondary transfer roller engaging mechanism.which involves the feed motor and a solenoid and the mechanism.
in the diagnostic menu ,there are some component tests you can run and one of them would be the secondary (transfer 2) test.which would run the feed motor and the secondary transfer solenoid ,some path rollers and should move the mechanism.it should lift it ,i think about 1/2 inch or so.if you do the test you may have to listen for the motor,or the solenoid to click,and you should be able to see if the 2ndary transfer roller raises.overriding the door switch can help also so it can be done with it open.
the door switchshould be on the upper left inside right inside and in back of the control panel,plastic piece sticking out of the front door there would normally depress the switch when closed.the secondary transfer roller is in the bottom in the paper path towards the back of the printer from the paper pickup unit.if the cartridges are out,you should be able to see it going across the paper path down there.should have a blue handle like on it's right side.
I own a hp 3700
first, in printer menu, there must be something like color calibration or adjustment, its auto procedure, try to do that and then print demo page.
Second it can be that the image transfer belt/roller needs to be changed or laser unit needs to be cleaned.
Hope that helps!
I have an error showing 49.4C02
Press STOP to clear the print job from memory
Power cycle the printer
Try printing a job from a different application.
Try a different driver i.e. PCL5 instead of PCL6
If you have extra memory DIMMs installed, take them out and try printing.
I have been offered a HP Colour Laserjet 3700dn to
D is for Duplex. You can print at both sides of the paper. N is for Network. It means that your machine is equipped with a network Interface.
The display should say "READY" when finishing the initialisation process. Try connect a computer and see if it will print. There is a small pin hole at the left side cover. put something small inside that hole and press the hidden switch. That should start a "Engine Test". The printer will print a single page with horisontal lines. If the test page comes out perfect, it's probibly something wrong with your Operator Panel/Display. If you are thinking about replacing the panel/display, here's the part# RM1-0511-000CN
NEED TO REPLACE dc CONTROLLER ON HP 3700N
Remove the left cover.
2 Disconnect all cable connections (19 connectors for the HP Color LaserJet 3500 series printer and 20 connectors for the HP Color LaserJet 3700 series printer).
3 Remove four screws (1) and remove the PCB (2).
I want to reset counters for fuser and transfer
Hi schoeller:
Hope this helps.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
To reset the transfer unit count, do the following:
1. Press MENU to enter the MENUS.
2. Press down arrow to highlight Configure Device.
3. Press check to select Configure Device.
4. Press down arrow to highlight RESETS.
5. Press check arrow to select RESETS.
6. Press down arrow to highlight RESET SUPPLIES.
7. Press check to select RESET SUPPLIES.
8. Press down arrow to highlight NEW TRANSFER KIT.
9. Press check to select NEW TRANSFER KIT.
10. Press down arrow to highlight YES.
11. Press check to select YES.
To calibrate the printer, do the following:
4. Press down arrow to highlight PRINT QUALITY.
5. Press check to select PRINT QUALITY.
6. Press down arrow to highlight CALIBRATE NOW.
7. Press check to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
To reset the fuser count
5. Press check to select RESETS.
8. Press down arrow to highlight NEW FUSER KIT.
9. Press check to select NEW FUSER KIT.
The fuser count is reset and the printer is ready to use.
Hope this helps.
