20 Most Recent
HP Workstation xw4200 PC Desktop Questions & Answers
I TRIED TO REFORMAT WITH
open command prompat
enter the command which i given bellow and put the drive adress after (:) colns
format C:
or any other drive name which you want to format like format D:
press enter and then yes
5 beeps are coming and after some time five beeps ...
Hi ,
When you hear 5 beeps while booting or turning the computer off it is related to the operation of critical motherboard components - such as the CPU.Please try these steps to try fixing this problem .
Open up the computer tower and then once the side panel is out a test on the motherboard needs to be done and to do that look for the memory cards(Ram ) which would be green in colour,4 inches long and would be inserted in a slot that has clips in either ends that holds the card in the slot firmly.There can be one or more than one so remove the memory cards and then turn the computer on by just connecting the power cable,you should hear long beeping noise if you dont hear any then the motherboard needs to be replaced or needs to be serviced.
allthe best
I am Having HP Xw
good luck with VISTA the dead OSdead at HPDead at MSDo you have SP2 loaded from MS, it's a must.but will run your CS3 (and did)i bet ADOBE does not support it now.your RAID array needs work, resync it.that raid,run full diagosics on itcheck the log files, (event viewer) for raid errors?you got em.
MY HP 4400 DOES NOT SEE MY SLAVE DRIVE
wonda,do you mean it's not in computer.your drive is RAW there for you can't se it.go to administrators tools COMPUTER MANAGEMENT.OPEN STORAGE.and DISKMANAGEMENT LOCAL.there you should se the drive now you can fomat the volym.let me no if any problem.
