20 Most Recent
GE Profile PT970 30" Built-In Double Electric Microwave/Convection Oven, Sensor Cook, Precise Air Questions & Answers
Changing the lamp in microwave of GE model pt970srss
If it is at all like a plain microwave oven, you will have to remove the screw for the cover to access the insides and likely will find that the light is not a simple screw-in bulb but a sealed package with a spare of spade terminals on top. It may be held in by one or more screws.
It is possible that this could be like a new conventional oven where you have to remove a light cover inside the cavity to access the bulb and change it
Turntable turns when door opened
This is usually caused by a defective door switch, or it may be out of aligment. Since there are a few of them a digital meter is required to troubleshoot the problem area. If you have the equipment I well describe how to test them.
My GE space maker model JVM240BL001 the power is on the digital display reads Enter NORM SOUND 2
Hello, friend! It is noteworthy that if the GE Spacemaker microwave model JVM240BL001 is displaying "Enter NORM SOUND 2" on the digital display, it indicates that the microwave is in the programming mode for adjusting the sound level. To exit this mode and return to normal operation, you can try the following steps:
- Press the "Clear" or "Cancel" button. This should clear the programming mode and bring the microwave back to its normal state.
- If pressing the "Clear" or "Cancel" button doesn't work, you can try unplugging the microwave from the power outlet for about a minute. Then plug it back in and see if it resets the display.
- If the issue persists, consult the user manual for your specific model. The manual may provide additional instructions or troubleshooting steps to resolve the issue.
