20 Most Recent HP Pavilion a1000n (PS567AA) PC Desktop Questions & Answers
I can't get it to go to the internet
What OS operating system. we cant guess that ever.0s2, linux, windows 98 2000,xp w7, w8.w10? what?No modem model and name statedno router, stated, same. model or number.do other PCs work here wired to same ethernet jack.?the PC is old. and zero support nowso this is what we do , now. using a scanner to find out what Ethernet chip is there.http://pcdied.com/chicken-egg.html
7/19/2017 6:09:53 PM • HP Pavilion... • Answered on Jul 19, 2017
How do i reboot and recover a windows xp media center a1412n without a recoverey disk or windows setup disk
Use a thumb drive. You can download the software from microsoft. And do not share your product key online...
2/28/2015 9:05:38 AM • HP Pavilion... • Answered on Feb 28, 2015
2answers
How can i repair the startup file so windows will
u can go to shop
2/5/2013 1:43:33 PM • HP Pavilion... • Answered on Feb 05, 2013
if you have a modem and a router you may have the router hooked up to the computer but it may not be hooked up to the router I only mention this cause i have made this simple mistake more then i care to admit
11/22/2012 12:34:33 AM • HP Pavilion... • Answered on Nov 22, 2012
2answers
My computer runs constantly its loud and annoying
I assume you mean the cooling fan on the CPU, this model uses a smart fan technology, it is meant to spin up faster to provide cooling. If is is doing tis constantly, it means the CPU is not getting adequate cooling (overheating), to check this, remove the side panel, clean all the dust and debris build up from the cooling fan and see if that helps
8/21/2012 5:47:01 PM • HP Pavilion... • Answered on Aug 21, 2012
3answers
If my HP Pavillion a1000n
Poor performance could be down to a number of reason's but adding memory is usually good value.
you can visit http://www.crucial.com to find out what additional memory (if any) you can add to your machine and how much it will cost.
Also worth making sure your anti-virus is up to date, that you have a decent amount of free hard disk space (at least 1Gb), defrag your hard drive if possible and run a good anti-malware scan to make sure there isn't any dodgy processes hanging about....suggest downloading and running the free edition of MalwareBytes - http://www.malwarebytes.org/products/malwarebytes_free
I hope this helps and good luck! If you have more questions - ask away!
Please take the time to rate this answer
Many Thanks K.
6/20/2012 9:01:18 AM • HP Pavilion... • Answered on Jun 20, 2012
I have a computer that
With the issue you are having, it only indicates that the operating system is corrupted together with the recovery partition. At this point, all I recommend you to do is contact HP at 866-408-5408 and request for a recovery disc. This will reload the operating system and all the drivers plus the default programs that came with it when you first got the computer.
About the charges now, you can click ths link and inquire how much it will cost you to get this issue fixed. FixYa does not charge depending on the number of questions you ask but the resolution of the problem. If your issue is not fixed then the amount you paid will be refunded back to you. In full.
9/13/2011 1:33:25 PM • HP Pavilion... • Answered on Sep 13, 2011
0answers
2answers
HP had blue screen and said it would shut down.
Hold the power button in for 10 to 15 seconds for hard shut down if that doesn't work unplug power for about 5 minutes then plug power back in and see what happens
3/9/2011 7:05:10 AM • HP Pavilion... • Answered on Mar 09, 2011
Fresh install of windows xp
I doubt, due to no support from Microsoft, anyone still supports XP. The nearest drivers I can find are Vista32 bit drivers.
Have fun and good luck.
How about Win2000 drivers, they are very similar?
12/15/2010 8:44:36 PM • HP Pavilion... • Answered on Dec 15, 2010
4answers
The hard drive in my HP A1000n Computer crashing
according to the model you have these are the ones that were built with this computer . One of these is in your computer . Which one of these is your drive ? p/n is on right side
PS591-69001 200GB S-ATA hard drive - 7,200 RPM (Seagate, Quiet)
DK322-69001 80GB IDE hard drive - 7200 RPM
DF283-69001 160GB IDE hard drive - 7200 RPM
please issue positive feedback for me
10/20/2010 12:09:08 AM • HP Pavilion... • Answered on Oct 20, 2010
Need memory for it
www.ebay.com
9/15/2010 2:57:10 AM • HP Pavilion... • Answered on Sep 15, 2010
"line in" unresponsive. "line out" and "mic" are ok. Any suggesti
Of course check the settings in the virtual mixer that the line in is not muted and volume is up.
REMEMBER that the line in on a lot of the machines is a low impedance input and MAY require more to drive it than some devices will deliver.
4/24/2010 8:24:40 PM • HP Pavilion... • Answered on Apr 24, 2010
2answers
Headphone volume not loud enough even with the
go to to computer on lower right bottom you should have a picture of a speaker open it up and make sure your settings are correct they can be adjusted there
1/24/2010 8:48:02 PM • HP Pavilion... • Answered on Jan 24, 2010
System Recovery Failure
Hp recovery console usually sucks, download an iso of the operating system from a torrent website like www.isohunt.com and do a fresh install. download the disc image burn the image to a cd, boot from the cd and fresh install, You will notice a world of speed improvment if you dont feel comfortable downloading the imange call hp and tell them you want a OEM disc of the os for your pc
11/17/2009 4:59:13 AM • HP Pavilion... • Answered on Nov 17, 2009
My 4 in 1 memory card reader is not functioning.
The card readers must have the correct drivers loaded.
Usually found on the driver CD provided with the machine.
Otherwise, you will have to google your machine style and card reader name "if any" for the drivers.
Also, if you are handy with PC's and not afraid to open the box.
Make sure the card reader is plugged UP!
If you have an exclamation point over any USB devices.
Probably:
a. don't have the drivers loaded or
b. The wrong ones have been loaded and failed. (Find and reload them)
10/3/2009 11:29:48 PM • HP Pavilion... • Answered on Oct 03, 2009
2answers
Power doesnt on
If you don't get any indication that power isn't working, e.g. a power light, computer fax noise, etc., it's likely that the power supply in the computer is no longer working. In extreme cases it can be the system board itself, but you should at least feel or here the fan in the power supply go on if it's still working.
Before going out and purchasing a new power supply for your computer I would try to at least plug in the computer somewhere else to see if any activity occurs when you attempt to power it on.
Hope this helps. Let me know if you need more help.
MO
2/11/2009 3:34:19 AM • HP Pavilion... • Answered on Feb 11, 2009
No suitible display device
Assuming you have XP
Do you have to original disks?
If so the info you seek is loaded in there,
you should be able to reload the drivers from the disk itself,
Go to Device Manager and right click properties,
Select device eg Sound,VGA,etc...
Click Update and point the wizard to the disk in your cd drive.
If you have no disk point wizard at the c drive where windows should have been installed.Let windows find the drivers.
Still can't find them then you need to do a windows update SP2 works so the machine can give the correct instructions to the right devices,at the right time.
Do the updates and reboot,then try again
I hope this helps ,please let me know thanks
7/16/2008 1:18:23 AM • HP Pavilion... • Answered on Jul 16, 2008
HP Pavilion a1000n (PS567AA) PC Desktop Logo
Popular Tags
33 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
repair startup file windows will
  • Computers & Internet
